View Poll Results: what should i do first
Mail order tune
27.78%
1.6 rr's and lt4 valvesprings
72.22%
Voters: 36. You may not vote on this poll
what to do first
Old Dec 26, 2006 | 10:26 AM
  #16
Originally Posted by sssalah
.....The LT1 stock tune is almost dead on for stock motors, like yours. It's only needed on more radical setups. Basiclly you don't need it unless it has a bigger cam.....
The stock tune has a way-too-rich 11.7:1 target A/F ratio in power enrichment (PE) mode. Anyone can net an easy 10-15HP on a stock setup simply by leaning out the PE mode tables. The mail order tuners who post here guarantee the gains.
Old Dec 26, 2006 | 07:24 PM
  #17
OutsiderIROC-Z's Avatar
Originally Posted by JoeliusZ28
if you plan on doing both definitely rockers and springs first. no sense in tuning twice.
Good point.
Old Dec 26, 2006 | 08:47 PM
  #18
ttop1986's Avatar
Do the roller rockers first, then the tune. No sense in tuning twice, just like what the others have said. Plus you said your on xmas break, that gives you plenty of time to do the rockers in case you have trouble. A tune you could easily do anytime you want.
Old Dec 27, 2006 | 12:12 PM
  #19
2000GTP's Avatar
You won't need your PCM tuned for the rocker arms.
Old Dec 27, 2006 | 01:11 PM
  #20
etex95's Avatar
couple quick things 1) do i need to get new hardened pushrods (111,xxx miles) and two are there any springs that would work for me that are somewhere inbetween the lt4 and 918's. i will most likely upgrade to a hotcam but i might decide to go a little bigger.
Old Jan 1, 2007 | 08:50 PM
  #21
etex95's Avatar
bump for some more info.
i think that i might go with something along the lines of the cc 305 (maybe a littel bigger) when it gets cammed.
Old Jan 2, 2007 | 02:40 PM
  #22
Z-RATED94's Avatar
Sorry this is all I have to offer, but it really seems like you need to save up before you ask about cams also. And when you think you have enough, save up another 50%. You going to be shocked what it cost to do just a cam change with the "right" parts and just a mail order tune. If you can't do it the correct way, don't do it. And even then something can go wrong and leave you without a car and or a very large repair bill.
Old Jan 2, 2007 | 02:43 PM
  #23
2000GTP's Avatar
Exactly, and there are always those unexpected problems that come up as well.
Old Jan 2, 2007 | 03:17 PM
  #24
etex95's Avatar
just throwing that out there as a future goal so that i get the right parts now.
i have absolutely no intention of touching a cam for over a year. right now it's strictly rr's and springs. If when i get all the parts for this install i dont have the cash on hand to install i can wait since that's the most expensive part of all this.
Back on topic now, what springs would i need for this cam or one with similar numbers? my budget is about $500 for this, i got the rr's for 100 so 400 left for install and springs. if yall dont think i can have a set up that would handle the 305 or similar tell me.
Old Jan 2, 2007 | 03:37 PM
  #25
MeanGreen97Z's Avatar
Drive it to Dallas and we can install those springs. We'll git er dun.
Did you get self aligning rockers? What about pushrods and guideplates?
Old Jan 2, 2007 | 03:43 PM
  #26
etex95's Avatar
i believe that these are SA not 100% sure any way to check, i havent bought em yet, a mechanic at local shop has em? as for the drive to dtown that could work out. i dont know what weekends are free yet since schools out right now. guide plates and pushrods for NSA right?
Old Jan 2, 2007 | 03:49 PM
  #27
Z-RATED94's Avatar
Originally Posted by etex95
i believe that these are SA not 100% sure any way to check, they're not in my possestion yet a mechanic at local shop has em? as for the drive to dtown that could work out. i dont know what weekends are free yet since schools out right now. guide plates and pushrods for NSA right?
Here's 2 more cents worth. If you are going to cam it, even a small cam, you need to go with NSA rockers and the right guides.
Old Jan 2, 2007 | 04:28 PM
  #28
sbs's Avatar
sbs
Only in the same sense that you don't need it tuned for the stock motor.
If you want the most performance from mods you need to tune for them.
Old Jan 2, 2007 | 04:43 PM
  #29
I have some 1.6 roller tip rockers and brand new lt4 valve springs I'll let you have for 90$. I'm buying my 1.7s soon and getting a better set of heads than the LE1 budget heads I had.
