crap, its allways something stupid!
Old Dec 31, 2006 | 04:32 PM
irishz28's Avatar
hey guys. so i had a nice little suprise today. i just got my car fully broken in, golen 383, le2 heads and le4 cam, and i was beating on it alittle today, and after i got home i went to check my oil and a pretty decent chunk of my dipstick tube has broken off, right at where the hash marks are down. i still havent gotten around to trying to get the piece out, but i was wondering if the dipstick tubes and stick are diffrent for a 4 bolt main block as apposed to a 2 bolt main block. when i put the engine back together i used the stock dipstick and tube off my origonal engine. i had to cut the end of the dipstick tube to clear the 4 bolt main cap, maby i should have done something with the stick as well.
Old Dec 31, 2006 | 05:05 PM
Blownbird355's Avatar
I added splayed 4 bolt and had to bend mine then when I filled it with the correct amount of oil I checked to see if the dipstick still registered correctly.
Old Jan 1, 2007 | 11:56 AM
irishz28's Avatar
ttt
Old Jan 1, 2007 | 12:36 PM
The Engineer's Avatar
With my Golen 396 I did not have any clearance issues with either the tube, or the dipstick. And, I used the OEM factory tube and dipstick. By design, it should pass the 4-bolt main cap and extend down (between the crank counter-weights) into the deep section of the oil pan. However, if something was out-of-alignment (bent) I can see where it might get into the path of a counter-weight.
WD
Old Jan 1, 2007 | 04:06 PM
irishz28's Avatar
this is a really wierd problem, maby the stick was in a wierd position, maby it got thrown into a counter weight while i was thrashing on it. ive heard the the part #s for the dip sticks on corvettes are diffrent than f bodys. are the corvette blocks all 4bolt main. maby that dipstick will be a better fit.
Old Jan 2, 2007 | 12:44 PM
irishz28's Avatar
ttt
Old Jan 2, 2007 | 06:47 PM
irishz28's Avatar
has any one had this problem?
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
colts0455
Sep 22, 2015 02:03 PM
NewsBot
Sep 14, 2015 09:20 AM
