What is the correct oil pressure?
Old Jan 6, 2005 | 02:24 AM
Got-LT1's Avatar
Like the title says, I think mine's high. Running 10W-30 petroleum based and getting ~60 on the gauge when I'm on it.
Also the pressure drops off to ~30 when I get off the gas and just cruise or idle, is that normal?
Old Jan 6, 2005 | 03:20 AM
GreenDemon's Avatar
Re: What is the correct oil pressure?
Normal.
Pressure at idle will be from 20-40 warm, depending on outside conditions.
Pressure at WOT should be about 60.
As long as it stays between 20 & 60 at all times you should be ok.
Old Jan 6, 2005 | 09:02 PM
Fast Caddie's Avatar
Sounds normal. Shouldn't be less than 20psi at any time. I've heard and read that most engines need at least a minimum of 10psi of oil pressure per 1000 rpm for adequete lubrication. So rule of thumb... don't let your rpm exceed your oil pressure and you're set.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
Jul 4, 2005 05:00 PM
