What to change when putting 93 engine in 95 chassis
Old Aug 9, 2010 | 09:02 PM
brad3579's Avatar
The car is going to be used for spectator racing so the gauges other then the speedometer would be optional. I am hoping that I can change to the 93 ecm and a few wire connectors for the opti etc. I also have the 93 engine harness. Any info would be greatly appreciated.
Old Aug 9, 2010 | 09:34 PM
It would be way better to have the 95 PCM and engine harness. All you would need is the opti harness for the 93s non-vented opti.
Old Aug 10, 2010 | 06:53 AM
brad3579's Avatar
The chassis still has the 95 pcm and harness in it and I have the 93 connectors so that would work. Would I want to also change the 93 intake and injectors etc to the 95 and add the MAF.
Brad
Old Aug 10, 2010 | 08:15 AM
Brad
That would be a reasonable thing to do, as well. The fuel delivery lines would then mate up. Sounds like you know pretty much what is involved.
Old Aug 10, 2010 | 08:51 AM
brad3579's Avatar
Thank you very much for the help.
Brad
PCLZ28
Dec 24, 2015 05:19 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Jul 4, 2005 05:00 PM
