what are the chances
Old Nov 15, 2006 | 08:14 PM
camarodude04's Avatar
what are the chances of an engine blowing up on the dyno? or any kind of tech problems happening? thanks
Old Nov 15, 2006 | 08:17 PM
MachinistOne's Avatar
Thousands of cars on our dyno, the worst I have seen is a lifted head/nitrous explosion on a diesel puller pushing 105psi. Other than that, if the motor is assembled correctly you should not have a problem, the dyno will not abuse the motor any more than you would on the street with sticky tires.
Old Nov 15, 2006 | 09:10 PM
razor02097's Avatar
If its a new motor braking in the engine on a dyno is better then breaking it in on the street.
If its not a new motor chances are quite slim it will break. A dyno just measures from RPM point 1 to RPM point 2 in gear clutch out 1 pull pedal to the floor. So unless the motor is already hurt you shouldn't worry much.
Old Nov 15, 2006 | 10:55 PM
i just dont wanna walk in there with a engine and walk out with a blown engine. is a dyno tune any different then a pcm tune?
Old Nov 15, 2006 | 11:54 PM
SSQATCH's Avatar
There was a motorcycle gathering down south that had several bikes blow up. They were having a contest to see who could get the most power down and they would over-rev and push the bikes to thier limits. So if you push it beyond it's limits (just like on the street), it can go. If you are just tuning and can see when the power starts to dive or know the RPM limit then I'd say you are safe.
TOM B
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 10, 2015 08:16 AM
michaelzilinski
Jul 31, 2015 08:41 AM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
