what is causing my car not to start?
Old Sep 8, 2004 | 05:51 PM
flusz28's Avatar
well all the wires were fine and the starter is good. i had to pull the starter when installing my new headers. so i installed it right back up. the old starter acted just like this one is doing now? they both don't want to inguage they just spin...these are all the mods i have done in the past couple months and haven't started the car since then until now. the factory starter had no shims so i put none on the new one. with these mods have no clue what would be keeping the starter from kicking in? please help Thanks , if i misunderstood the map sensor wires, the car would still fire up. right?? the motor is turning right now. all fuses are good. would a tune on my computer have gone wrong and not let the car kick over? anyone have that happen?
vortech s-trim
42lb injectors
255 fuel pump
computer tune from madz28
2 bar map sensor
msd btm box, but isn't wired up yet.
ac delco plugs with like maybe maybe 10miles on them
new accel 1200 heat wires
Old Sep 8, 2004 | 10:25 PM
Re: what is causing my car not to start?
It would be much better if you kept your original thread going instead of opening a new one. Makes it confusing and hard to understand/follow without any reference.
I am confused when you say your starter does not engage and then you say the motor is turning. I also don't know what you mean about the MAP wires.
Old Sep 9, 2004 | 07:58 AM
flusz28's Avatar
sorry bout that, well what i mean is the car acts like it wants to start for a second or so then they starter starts to spin like crazy when you hold it longer, and i tapped it over and still nothing... like the order of the wires as to how i put them in the map sensor 2 bar plug. maybe i have them backwards from your drawing? but the car would still fire though.. i unhooked the msd box and put the stock coil wires back to normal and nothing. coil is getting power. guy i just talked to online said that my tuned stock pcm can't read a 2 bar map sensor??? is this true?? i was told by bunch of people i needed to upgrade it... i hear no backfire ir anything from the motor, so no spark i would guess...
Old Sep 9, 2004 | 11:47 AM
If the engine is spinning unusually fast with the starter, that can mean there is no compression. Have you been messing with the valves? Don't know about the PCM reading the 2 bar MAP.
blac94Z
Dec 2, 2014 12:09 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
1LEThumper
Jul 14, 2003 12:45 PM
