What are the causes of a stumble/hesitation??
Old Jul 27, 2003 | 10:56 PM
speed76demon's Avatar
Arrow What are the causes of a stumble/hesitation??
I have the very common hesitation in my car. It is more common when my car is warmed up. Mostly in lower rpm's but doesnt pull like it should in the upper rpm level. It just kinda has nothin when u press the pedal in the lower rpm then sometimes will catch and just take off or sometimes it might backfire. Any ideas b/c im taking it to the shop next week to get the plug wires done on it so anything else i could tell them to check?
Old Jul 27, 2003 | 11:13 PM
jasons93z's Avatar
i would check the coil first. Its cheap and that was the cause of my problem. If not that, then its more than likely the opti.
Old Jul 27, 2003 | 11:19 PM
cals400ex's Avatar
stumble at low rpm's could be O2's or egr. usually high rpm miss is the coil, however it is cheaper than the opti so try that first. plugs and wires could also cause the hesitation. i would also clean your maf sensor. it could be several things, but O2's and egr should not matter when doing full throttle. see how it is after the plug/wire change. it that doesn't fix it, it may be the opti.
Old Jul 28, 2003 | 10:08 AM
i have already replaced the coil and i put in new 02's when i did my header install
Old Jul 28, 2003 | 11:37 AM
TobyZ28's Avatar
What type of O2's?
I have bosche O2's and my car is still sputtering at low rpm exactly like you described. I think they might be causing it to run rich...
Old Jul 28, 2003 | 11:58 AM
i used ac delco 02's
Also after my header install i can hear that air leak sound comin from my egr i believe. You know the one that some ppl add restrictor plates so it doesnt make the noise would this cause any type of hesitation?
Old Jul 28, 2003 | 12:03 PM
cals400ex's Avatar
an egr valve not funtioning properly could very well be your problem.
Old Jul 28, 2003 | 12:10 PM
scoobysnax83's Avatar
An EGR valve not operating correctly is your problem! If that is the case.
And.....do the plugs and wires yourself. Its a PITA, but you'll save soooo...... much......$$money$$ I hate seeing people being burned by mechanics. I actually burned the dealer so I was one of the lucky few. Good Luck
Old Jul 28, 2003 | 07:20 PM
i also have oil leakin on my opti but u think that the egr is my problem?? whats makes u so sure?
Old Jul 29, 2003 | 08:50 AM
You misread what I posted.... I was trying to say that if you have a bad EGR valve, the symptoms that you described would go hand and hand with it.
EnFuegoZ28
Jun 1, 2009 02:03 PM
nodnarb481
Jul 4, 2006 04:40 PM
Fastbird93
Feb 12, 2004 05:25 AM
Fastbird93
Advanced Tech
17
Feb 5, 2004 07:04 PM
BigTed187
Dec 19, 2003 06:26 PM
