Stumble/hesitation??
Old Dec 19, 2003 | 05:08 PM
BigTed187's Avatar
alright i got a problem?? i have a 1995 z28 with 150k miles on it today. The past few days its been popping non stop from the exhaust and i have a stumble/hesitation problem but gets worse after the car has been runnin for more then 5 minutes...I was wondering if the timing is off, cuz i havent had it tuned in the past few years and ive also put bigger fuel injectors in??? any ideas?? thanx alot
Old Dec 19, 2003 | 06:11 PM
Fastbird93's Avatar
Timing shouldn't be off unless you've messed with the timing chain.
Check your plugs and wires first and foremost. It's very common for a wire to burn and cause a stumble and hesitation.
Old Dec 19, 2003 | 06:17 PM
BigTed187's Avatar
i just recently put all new plugs and wires in ....no problems there...replacing fuel injectors with 4 lbs bigger injectors that would mess up the fuel/air ratio??? i was also wondering since i have a oil leak, and it looks to me the opti has been covered in oil...car still starts though, but stumble every time i step on it. i do have a poppin noise though soo i was wondering if the timing had been off on that??
Old Dec 19, 2003 | 06:26 PM
Fastbird93's Avatar
You're definitely in dire need of a tune if you went from 24 to 28 pound injectors. I bet you're running VERY rich right now.
If the opti got covered in oil, that could be bad. It could be all right though.
If it helps, my car is running super rich right now for some reason. And when I get on it, it stumbles and hesitates.
Get a tune for it and go from there. Both PCMforless.com and madwolf (madz28.com) do great tuning.
EnFuegoZ28
Jun 1, 2009 02:03 PM
Mtxz453
Oct 16, 2008 05:56 PM
nodnarb481
Jul 4, 2006 04:40 PM
Fastbird93
Feb 12, 2004 05:25 AM
Fastbird93
Advanced Tech
17
Feb 5, 2004 07:04 PM
