What causes a spun bearing?
The primary cause of a spun bearing is that it occurs due to lubrication failure. Causes include oil starvation (as in hard cornering for prolonged periods or just running the oil level too low) oil breakdown (failure to change the oil), oil contamination (internal coolant leaks or dirt), failed oil pump, oil pressure relief valve stuck open, etc.
Rich Krause
Rich Krause
jackpawt883
Sep 10, 2015 08:53 PM
