What causes an SES light while driving for more than 5mins in 6th gear?
Old 08-27-2003, 05:21 PM
Robbie's Avatar
After my header install about a year ago when I ride in 6th gear for a few mins i get an SES light. I can turn the car off for 10 secs and start it back and the light goes away and doesnt come back on unless im in 6th gear again for more than a few mins. Has anyone had this problem? I cant remember if i seen someone post about it or not but i think i did. Could it be because of the EGR crap being gone?
Robbie is offline
Old 08-27-2003, 05:28 PM
BlakeW5's Avatar
I can't offer advice about the 6th gear deal, but it sounds like your EGR. Mine (A4) does this to. I drive for a while the light comes on, and turns off after I restart the car. I had the code scanned at autozone, and they said it was the EGR and I would need a new one, or need to clean out the old one. No big deal really, I'm taking it off when I get headers anyways.
BlakeW5 is offline
Old 08-27-2003, 06:48 PM
94formulabz's Avatar
High map possibly because there should be a lot of vacuum at low rpm low throttle. I had this after i removed the map sensor to get to a intake manifold bolt. If you aren't carefull the orange rubber seal doesn't go in straight and will leak. It could be any other kind of minor vacuum leak though. Why not just get it scanned though and quit the guessing?
-brent
94formulabz is offline
Old 08-27-2003, 07:35 PM
Probably EGR. You can always scan it to see what the code is.
shoebox is offline
Old 08-27-2003, 08:23 PM
Wize1's Avatar
mine happened within first 2 years.....EGR
Wize1 is offline
Old 08-28-2003, 11:49 AM
Robbie's Avatar
I try gettin it scanned at AutoZone but the OBD1 scanner didnt fit my connector on my car. The connector on my car is the same design as the OBD2 cars. So he swore up and down i had OBD2 and I kept telling him no it wasnt. I got home and looked up some parts and found an adapter to make the scanner work for my car. So my basically has an OBD2 harness yet an OBD1 computer. Im guessing all 95's are like that yes?
Robbie is offline
Old 08-28-2003, 12:44 PM
magius231's Avatar
all 95's are like that. If you want to do this yourself, order a cable from Andrew Mattei for $60, download Freescan and check the code yourself. You can even do it on a desktop computer if you can get it close enough (alternately I believe Andrew sells an extra long cable as well.)
magius231 is offline
Old 08-28-2003, 01:57 PM
JWA95TA's Avatar
Yeah probably EGR code. Funny I still get that code in the same conditions and I dont have an EGR valve anymore!!
Jason
JWA95TA is offline
Old 08-28-2003, 02:01 PM
RedPhenx's Avatar
mine always did that.. when the opti died and i replaced it, problem went away.. dont know of the correlation though.
RedPhenx is offline
Gtpguy
01-26-2015 04:50 PM
sleeperZ96BT
06-05-2005 09:33 PM
Rich_z28
09-13-2002 03:35 PM
Z28Wilson
08-01-2002 04:27 PM
Doug Harden
11
07-14-2002 04:31 PM
Quick Reply: What causes an SES light while driving for more than 5mins in 6th gear?
