what causes arcing? Please help (brand new plugs and wires)
Old Mar 26, 2004 | 08:56 PM
licerio's Avatar
i have a vibration 1500 - 2200 rpm and sometimes a pop in the exhaust on under load. i found at the i have an arcing in the passenger side front and the coil....
I have a brand new taylor wires and NGK plugs,,, what causes this... and how to fix it. thanks
Old Mar 26, 2004 | 09:20 PM
GreenDemon's Avatar
Electricity takes the path of least resistance, so if there's a gap that's easier to bridge than the one on the spark plug, it will take that route instead. Did you use di-electric grease? The boots should make popping noises when you pull them off the terminals. Other than that, just make sure all the boots are as snug as possible. Use electrical tape if neccessary. That's what I'm using right now as either my belt or pulley decided to wear through my #4 wire- on my Accel Extreme 9000s . It made it right to the conductor and then the cylinder went dead.- What's funny is I found out by pulling off the connectors for the injectors one at a time till I found one that didn't have any effect.
Old Mar 26, 2004 | 11:05 PM
licerio's Avatar
man, we did not use any grease on the plugs when we install them I have NGK and some taylor's. Do I have to use grease?
can you explain it more my route (no experience). cant understand it that much.
what do i need to fix it? do i need to change the plugs completely or wires? is it bad to drive it for a lilttle while. I cant get my car to my mechanic until tuesday. is that going to hurt the engine...
also my coil is arching as well...to be honest i really dont know what arching is, just I see all this blue lights....lol.
PLEASE HELP.. this car got so much trouble..
now my AC IS NOT BLOWING COLD...WHAT THE HELL IS THA DEAL!
Old Mar 27, 2004 | 07:16 PM
licerio's Avatar
I am bringing my car back to the people who installed my plugs/wire and they said theyre going to check it out.
if there is only some places arching, do I have to replace those plugs with the same plugs that is on the other cylinders?
I guess what I mean is I am using NGK TR55, if one plug is crack, can I replace that plug with something else?
is TR55 easily available? thanks
again, what is the cause of arching?
PCLZ28
Dec 24, 2015 05:19 PM
chevy95z28
Jun 22, 2015 09:28 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
IRABuss
Sep 7, 2011 09:08 PM
