What can i use to hold the window up
Old Mar 6, 2004 | 10:21 AM
jsz28's Avatar
Im in the process of changing my window motors and need something to hold the window up so the spring wont pull it down. What can i use that is safe to hold the window up.
Old Mar 6, 2004 | 11:39 AM
drewstealth's Avatar
i would use a C-clamp to hold it up
Old Mar 6, 2004 | 12:06 PM
Shankels94TA's Avatar
a 2x4 will fit in one of the holes and hold the window perfect!
Old Mar 6, 2004 | 12:44 PM
slverbullet's Avatar
hey, just FYI: shoebox has a great write up on this with lots of pics and makes for a fast swap on motors.
Old Mar 6, 2004 | 11:06 PM
camarokid24's Avatar
I used duct tape to hold it up. Worked great for me
Old Mar 6, 2004 | 11:49 PM
93Z286Speed's Avatar
i used shoebox's write up and used a c clamp with tape on it to hold the window.. worked great
Old Mar 7, 2004 | 09:26 PM
Fatdog's Avatar
Cool
I couldn't see spending money on clamps for a one time use(din't consider the pass window someday da),so I used a pvc pipe,like the one from the sprinklers,and cut a large V at the top of it to hold the window in place,and it worked just fine.You just cut to length,test it ,and cut again till it is tight(up to the window glass,and down to the base of the door frame).I can't remember if I used one or two of them(need a defrag of the grey matter).Hope this helps.
Old Mar 7, 2004 | 10:35 PM
Red96Lt1's Avatar
I have used quick grip clamps before since the pads on them are more window friendly than a c clamp.
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
z28cam1993
Sep 9, 2015 04:08 AM
