what can cause my knock?
Old Mar 21, 2004 | 10:37 PM
Seal's Avatar
I autotapped the car today, and i picked up 7 degress of knock at max... it would fluctuate between mid 4s to 7.0
i'm running on 93 octane, and my cam has a tune from ion...
what would cause the knock?
i thought it was false knock, but i capped my exhaust (closed the cutout) and still got the knock (it was actually worse)
what can this be from?
Old Mar 21, 2004 | 10:41 PM
PatriotTA's Avatar
If you have headers, they could be the cause. Also a noisy valvetrain like aftermarket rockers and such could also cause false knock. Do you have a stock knock sensor, or an LT4 one? If you still have the stock one, I'd reccommend you pick up the LT4 version which is less sensitive.
Old Mar 21, 2004 | 10:46 PM
Seal's Avatar
i do have a lt4 KM and also my tune includes knock desentasition(sp)
Old Mar 21, 2004 | 10:56 PM
96ta(nick)'s Avatar
i am picking up *5 even with my lt4km
Old Mar 21, 2004 | 10:57 PM
mPoRtSsUcK's Avatar
what can the cause be tho...
if i/we can eliminate this, it would def give us some more power
Old Mar 21, 2004 | 11:09 PM
JSK333's Avatar
Too much advance and/or not enough fuel.
Old Mar 21, 2004 | 11:42 PM
mPoRtSsUcK's Avatar
i'm actually running rich...
Old Mar 22, 2004 | 12:48 AM
96ta(nick)'s Avatar
hmm same here
Old Mar 22, 2004 | 05:46 AM
CoUnTryMuZiCZ28's Avatar
When i dynoed i showed a max of 9. something degrees of spark retard.. Mine was because of an exhaust leak.. It should be all fixed now. I hope..
Old Mar 22, 2004 | 10:49 AM
JSK333's Avatar
If you've been running rich, your plugs could be fouled, which I've seen can cause pre-ignition.
When I changed my plugs after getting knock on nitrous, the knock went away. The old plugs were fouled.
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
whitehooptie
Aug 10, 2015 07:02 AM
