what cam with stock heads?
Old Nov 2, 2011 | 04:41 PM
  #16
dennis5374's Avatar
Re: what cam with stock heads?
The key is usable power. You wont make peak power with That 847 until 6k plus. Even a refreshed stock bottom end won't like being turned that high for to long. I think my cam was overkill for stock heads. I was making peak power at 5900-6000. After that the power descended pretty rapidly. I also believe a custom grind will give you the best of both worlds. If you want screaming top end buy the biggest cam offered and shift it high on borrowed time. If you want a noticeable difference good low mid and top end go with a cam that's custom ground too fit your needs.
Old Nov 3, 2011 | 10:00 AM
  #17
Slo-LT1's Avatar
Dennis thanks for the info def something I'm gonna check into
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
Brian-94TA
Jul 31, 2002 02:52 PM
