What cam? Need help fast.
Old Oct 26, 2006 | 10:58 PM
96ZCamaro's Avatar
Alright well my motor is in the machine shop right now. Getting all new bearings. Stock crank and rods. Ported cylinder heads with port matched intake. Not sure on the flow #'s on them. 1.6 s/a roller rockers (yes i know not the best, but what I have to work with). New pistons, gonna be a little higher compression due to thinner head gasket and also they are a little bit higher compression pistons too. Machinest said about 10.75 to 1. But I really NEED to find a cam for this thing fast. Dont want to do custom grind beings how I dont know the flow #'s and due to time. I want to get the most power out of this thing I can without going solid roller or anything like that. Just a regular hydraulic roller cam. Want bigger then the cc306 probly. Help greatly appreciated.
Old Oct 26, 2006 | 11:03 PM
JohnnyPappis's Avatar
Id call comp and ask for there advice also how much power you wanna put down drivability? ide all important facotors when selcting a cam also bigger ive leaned isnt always better you want somthing to match ur heads compression and displacement you dont want to over cam a car
TheGreenZ28
Oct 4, 2020 11:29 AM
rideordie
Nov 5, 2019 04:52 PM
May 15, 2015 10:43 AM
Queens94z28
Nov 20, 2014 06:03 PM
