What Cam with NA 383?
Old Nov 30, 2004 | 08:05 PM
  #31
got_hp?'s Avatar
Re: What Cam with NA 383?
i havent put the motor in yet, but mine is 238/245 .580/.591 on 112
i told alan futral i wanted a big cam but still retain power brakes and i daily drive 70 miles, thats what he chose.
Old Nov 30, 2004 | 08:19 PM
  #32
1racerdude's Avatar
Mine is a 260+@50 with 708-715 lift on a 112 and has a measured 11 in of vacuum.The brakes and air work fine. The only brake problem is if you inch up in traffic and repeatably hit the brakes.I put a vacuum can on and no problem since.
Not a bad choice Allen made, but a bit conservative.
Old Nov 30, 2004 | 10:10 PM
  #33
Kraest's Avatar
Retired
Originally Posted by LREFLYBYOU
That combo COULD be a high 9 second combination with a fuel system and LT1 Edit to tune it!I didnt say it could be as is...I said WITH A FUEL SYSTEM!
I COULD spray the car INTO the 9's with a good fuel system!If It was fully tuned for the 150 shot as it,i could go 10.90's.If I fully tuned it then sprayed it Hard It would go 10.0's 9.90'....
1racerdude is right. Slow motors are called "nitrous motors." The have the same forged components as their N/A counterparts, but lack one thing.... horsepower..
Old Nov 30, 2004 | 10:15 PM
  #34
1racerdude's Avatar
Well Said......
Old Nov 30, 2004 | 10:25 PM
  #35
SS MPSTR's Avatar
If the end justifies the means, who cares?
Old Nov 30, 2004 | 10:33 PM
  #36
dmoor88's Avatar
I know its pointless, but who out there has a N/A 383 with their stock heads? what sort of numbers did you lay down?
Old Nov 30, 2004 | 11:51 PM
  #37
LREFLYBYOU's Avatar
If it were my car it would be N/A,customers ask for things I build them. Its a nitrous motor in the sense the car was tuned with a simple mail order tune that runs his stock injectors maxed out all the time,and on motor the car is fat as hell and runs a whopping mid 12...on nitrous a simple small shot the car starts to lean out creating more hp...So I would say it is set up to run on nitrous bc it dogs on motor and it might not be the fastest thing on nitrous either,but its just a little shot it could go a lot faster...
I dont like nitrous much if I had to pick a power adder it would be blown like my Blown 57 Chevy...
Old Dec 1, 2004 | 08:39 AM
  #38
Kraest's Avatar
Retired
There's really no need to make a motor run rich like that all the time. If you want nitrous, add a wet kit and let the nozzles add the fuel instead of the injectors. The only way you'd need to tune big injectors on a motor in my opinion is with a blown motor. Why sacrifice drivability with huge injectors on a car that rarely sees nitrous being thrown at it. It's not like you need to drive to the store to get a gallon of milk and hit the button in the parking lot.
Mike
Old Dec 1, 2004 | 08:58 AM
  #39
got_hp?'s Avatar
[QUOTE=Not a bad choice Allen made, but a bit conservative.[/QUOTE]
well i think he was keeping in mind that i drive 70+ miles daily, and sometimes that can be in traffic.
eventually ill buy a daily beater and make the fbody more extreme.
Old Dec 1, 2004 | 11:28 AM
  #40
LREFLYBYOU's Avatar
Mike
they are stock injectors.
Old Dec 1, 2004 | 02:31 PM
  #41
Kraest's Avatar
Retired
I think you missed the point.
Old Dec 1, 2004 | 04:44 PM
  #42
Tibbys96Z's Avatar
Thanks for the advice and such! lol
We went with a .608/.613 112.
Old Dec 1, 2004 | 04:54 PM
  #43
flyinZ's Avatar
What kind of duration did ya go with?
Old Dec 1, 2004 | 08:26 PM
  #44
Tibbys96Z's Avatar
oops it is 236/244
Old Dec 1, 2004 | 08:36 PM
  #45
wantafastz28's Avatar
With stock ported heads? What a way to beat on the valve train for no reason.
