What Cam with NA 383?
Old Nov 30, 2004 | 08:40 AM
  #16
Gripenfelter's Avatar
Re: What Cam with NA 383?
I'm running an LE2 cam. PM NightTrain66 for details. Its like a GM 847 cam.
Old Nov 30, 2004 | 08:50 AM
  #17
Kraest's Avatar
Retired
Originally Posted by LREFLYBYOU
That same cam in a 355 lt1 was going mid 11's on a 150 shot with a simple mail order tune and a stock fuel system..
Stock crank and rods KB Hyper pistons,that cam mildly ported heads full bolt ons A4 little stall...So tell me again how that cam sucks?
My friend has a cam bigger than that (233 @ .050) with mild headwork and is going near 10s (11.03) on a 150 shot with a STOCK BOTTOM END 350 LT1.
So, once again that cam sucks. You can go 11s on a bolt-on car + nitrous, as shown by Joe Brodman and many many many many others.
I wouldn't brag about mid 11s on nitrous + heads/cam. Most people with good headwork + a nice cam go mid 11s on motor when everything is set up.
Just my $.04
Mike
Old Nov 30, 2004 | 08:59 AM
  #18
Tibbys96Z's Avatar
The heads flow 270/195. Also has a built trans with 4000 stall, 3.42 gears
240/240 .600/.600 112 sounds good! Do you have any track times or dyno numbers with that setup?
Old Nov 30, 2004 | 09:19 AM
  #19
The LE2s regularly put out around 420rwhp and trap 116-118mph. ETs are usually around mid to high 11s.
Old Nov 30, 2004 | 10:30 AM
  #20
LREFLYBYOU's Avatar
Just my $.04
Mike
Did u miss the part where I said UNTUNED!STOCK FUEL SYSTEM! if I tuned it and put a fuel system on it i could spray the car into the 9's!
Old Nov 30, 2004 | 10:36 AM
  #21
ejfagala's Avatar
I went with the CC 306 and made 414 RWHP/ 413 RWTQ and there is still more in it. I had a miss the day I tuned so I think it should be capable of 425+ with more tuning. I know there are newer cams out there that can make nore HP but I still get 19 MPG driving back and fourth to work and am hoping for 26 MPG + Hwy. If your interested my heads are AFR 195's and my CR is a fairley low 10.7:1
Old Nov 30, 2004 | 10:47 AM
  #22
Kraest's Avatar
Retired
If "if" was a skiff, we'd all be sailing.
You're "running" 9s in a dream before you're running low 11s in reality.
Nice. I wish I had an imagination like that.
Ok. Thanks for playing. Please drive thru.
Old Nov 30, 2004 | 11:01 AM
  #23
LREFLYBYOU's Avatar
Earth to retard I drive a seven second race car...9's would be a walk in the park!
Old Nov 30, 2004 | 02:05 PM
  #24
Kraest's Avatar
Retired
So? THAT car doesn't go 9s...or 10s.....or low 11s.
That's almost as stupid as saying "Hey! I have a 6 second motorcycle, but my LT1 goes 11s! In that case, my LT1 should go 9s, easily."
Give me a break, dude.
Mike
Old Nov 30, 2004 | 04:14 PM
  #25
I can gain 2 tenths just by lacing up my Nike sneakers tighter.
Old Nov 30, 2004 | 05:01 PM
  #26
1racerdude's Avatar
Put in a nasty 250/260@50 on a 108+4 with .685 lift SR and make some real HP will ya.
Old Nov 30, 2004 | 06:16 PM
  #27
LREFLYBYOU's Avatar
Mike
That combo COULD be a high 9 second combination with a fuel system and LT1 Edit to tune it!I didnt say it could be as is...I said WITH A FUEL SYSTEM!
I COULD spray the car INTO the 9's with a good fuel system!If It was fully tuned for the 150 shot as it,i could go 10.90's.If I fully tuned it then sprayed it Hard It would go 10.0's 9.90'....
Old Nov 30, 2004 | 06:53 PM
  #28
1racerdude's Avatar
You could go 10.9's N/A with that CID and it being RIGHT.---- Doing that--- Of course the heads, cam, fuel,and intake would have to be RIGHT.
EDIT: Thats at 3600lbs
Old Nov 30, 2004 | 07:44 PM
  #29
LREFLYBYOU's Avatar
Of course.But the heads are mildly ported along with the intake. The motor was built to run on nitrous it wasnt built to run n/a.
Old Nov 30, 2004 | 07:55 PM
  #30
1racerdude's Avatar
The smaller the heads the bigger the cam has to be to make it perform.
As far as "it is built to run on N2O" goes-- it's an excuse people use when they get outrun by a N/A car.
Make it run on motor then add the power adder.
