What Cam with NA 383?
Old Nov 29, 2004 | 07:17 PM
Tibbys96Z's Avatar
What cam do you NA 383 guys have? This will be with ported stock heads 2.0/1.58 valves.
Old Nov 29, 2004 | 07:25 PM
LREFLYBYOU's Avatar
Re: What Cam with NA 383?
07-502-8 is the cam I run in my N/A apps...Runs Awesome!
Old Nov 29, 2004 | 07:41 PM
Tibbys96Z's Avatar
I understand the Duration numbers, but what are the lift numbers with a 1.6rr?? I'm confused..
Part Number 07-502-8
Engine 1993-1996 Chevrolet
350ci,
LT1 & LT4,
8cyl.
Grind Number LT1 XR269HR-12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.495 0.503
Duration At 0.006 Tappet Lift 269 276
Valve Timing At 0.006
Open Close
Intake 26 62
Exhaust 74 22
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 218 224
Lobe Lift 0.33 0.335
Lobe Separation 112
Old Nov 29, 2004 | 07:52 PM
LREFLYBYOU's Avatar
well if they are judged with a 1.5 rocker ratio divide the lift number by 1.5 then multiply it by 1.6 or whatever rockers you have!
Old Nov 29, 2004 | 08:23 PM
Kraest's Avatar
Retired
Lobe lift * 1.6 = Lift with 1.6 rockers.
That cam is fu*king gay. There's no way I'd EVER put a 218/224 in a N/A 383.
Mike
Old Nov 29, 2004 | 08:25 PM
Kraest's Avatar
Retired
IMO, I'd do more like a (more streetable) 23x/24x HR @ .050 or maybe even a (less streetable) 24x/25x @ .050 HR on a 110 LSA for an N/A application.
Mike
Old Nov 29, 2004 | 08:27 PM
Tibbys96Z's Avatar
so this cam would be .528/536 with 1.6rrs? That seems really small.
Surely my calc must be wrong.
Edit. I thought that may be too small.
Kraest. We met in New Orleans about 4 to 5 years ago at Lake Ponchatrain (sp?) good times.
Thanks for the advise guys.
Just looking for a good combo to work well together....
Old Nov 29, 2004 | 08:30 PM
Kraest's Avatar
Retired
No, that's exactly right.
Like I said. That's a ***** cam I wouldn't put that sh*t in a N/A 350, let alone a 383. I'd probably put it in a daily driver truck or something.
Mike
Old Nov 29, 2004 | 08:36 PM
SS MPSTR's Avatar
Fairly close to my cam, and yet with a tune it's surprisingly streetable.
Old Nov 29, 2004 | 08:42 PM
Kraest's Avatar
Retired
Oh, definetly, bro. My cam in my 396 was a 240/240 112 @ .560 with 1.5s (I had 1.65s and 1.6s) and was plenty streetable... although when you blew the tires off the rims from a 55 mph roll, the car WOKE THE MOTHERFU*K UP and scared the diarrhea out of you.
Those AI heads + 383 + a big *** nasty cam must make you get a boner.
Mike
Old Nov 29, 2004 | 09:37 PM
Tibbys96Z's Avatar
This info is for another car, but my Z28 has the GM847, so I'd like to go bigger than that.
Old Nov 29, 2004 | 09:49 PM
SS MPSTR's Avatar
Get your heads flowed. Throwing a big cam at an unknown is a waste of time and money IMO.
Old Nov 30, 2004 | 12:16 AM
LREFLYBYOU's Avatar
Mike
That cam is in a mild 383 that is very untuned and goes mid to high 11's in a 95 6 speed car..
Old Nov 30, 2004 | 12:23 AM
LREFLYBYOU's Avatar
That same cam in a 355 lt1 was going mid 11's on a 150 shot with a simple mail order tune and a stock fuel system..
Stock crank and rods KB Hyper pistons,that cam mildly ported heads full bolt ons A4 little stall...So tell me again how that cam sucks?
Old Nov 30, 2004 | 01:19 AM
Deenasty's Avatar
im running a 240/240 .600/.600 112lsa cam with a set of ported afr 190's..Nice power..
