What cam can I get on a 110 lsa that'll have a good powerband up to 6000rpm?
Old Mar 2, 2007 | 04:48 PM
KillerTA's Avatar
I've probably read every cam post on this board and everyone has a different opinion.
Like the title says, what cam can I get on a 110 lsa that'll have an even powerband up to around 6000rpm given my current setup? I don't want a peaky cam and I want the engine to last. Driveability is not that important and this is a weekend driver.
Any input? I'm realy lost here after reading all the cam threads.
Old Mar 2, 2007 | 04:49 PM
speed_demon24's Avatar
Cc503
Old Mar 2, 2007 | 04:52 PM
MEAN LT1's Avatar
Custome grind.
Old Mar 2, 2007 | 05:11 PM
seawolf06's Avatar
Wouldn't a wider LSA give you a powerband more to what you're looking for? Try one of the smaller xfi grinds with some Comp 26918 springs, or a custom grind as stated above.
Old Mar 2, 2007 | 05:39 PM
Ram Air 383's Avatar
Crane 227
Old Mar 2, 2007 | 05:46 PM
seawolf06's Avatar
You can call the cam manufacturer and they can grind the cam on whatever LSA you want.
Old Mar 2, 2007 | 10:54 PM
You're going to get all the same different opinions in this thread like you have already seen. Talk to someone reputable and get a custom grind.
Old Mar 3, 2007 | 12:33 PM
Why did you pick a 110* LSA? Generally, that moves the power band higher in the RPM range, makes it less "street" friendly, and gives you problems with low vacuum at idle.
Old Mar 3, 2007 | 02:07 PM
seawolf06's Avatar
That's what I was saying. He wants a "even powerband" and doesn't want a "peaky cam", but that's exactly what he's asking for. Need to do more research, IMO.
oldschool
Feb 9, 2016 09:21 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Queens94z28
Nov 20, 2014 06:03 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
