what cam is best for daily driver??
Old Jan 6, 2004 | 01:46 PM
SiDeWaYZz28's Avatar
hey everybody what cam is best for a daily driver . . .i want the xe 230/236 but i dont want a big stall . . . by the way i have an a4 . . .i dont really want to have a stall if i dont hae to . . .what cam is out there a little bigger than lt4 hotcam???o yea and im not worried about smog . . well imma cut it short thanks for the help guys!!!!!!!
Old Jan 6, 2004 | 01:53 PM
LWillmann's Avatar
The XE 224/230 and the LT4 Hotcam are very similar with the XE coming out better with a flatter torque curve and lower rev requirement.
If you fear the XE 230/236 would be too much a require a stall, then why not split the difference and go with an XE 227/233 from Combo Motorsports?
Old Jan 6, 2004 | 02:02 PM
what kind of stall will i need for a 227/233??what are the stats of the lt4 hc??with the 224/230 need a stall???ill go the stall route but i just dont want a big one . . .sorry for all the questions im just new to the whole cam thing . . but thanks alot for your help
Old Jan 6, 2004 | 02:11 PM
FacelessZ's Avatar
What's wrong with having a higher stall than stock? Just curious...
Old Jan 6, 2004 | 02:15 PM
LWillmann's Avatar
Ok, stock stall speed is 1600 RPM...
SLP sells a 2400 RPM stall coverter (it's an adjusted stock one I think)
Most people recommend a 2600-2800 RPM stall for the milder cams.
The LT4 Hotcam is I believe 218/228 on a 112 LSA with .525/.525 lift.
The XE 224/230 is going to be 224/230 on a 112 LSA (but you can get it with a 114 to make it more Auto friendly) and I'm not sure of the lift. The lift depends on the lobes you chosse for the cam.
The whole purpose of a stall coverter is to get the motor into the cam's power band faster, so the car will get up to 2800 RPM (using a 2800 RPM stall as example) really quickly so you can get into the fat part of the power band and get moving faster.
Once you start upgrading the car, the power band shifts upward in the RPM range and the car has to work a little harder to get into the power band than it did simply because that band has now shifted higher.
A guy in my car club has a 2800 RPM stall converter, and at light throttle inputs it acts much like the stock converter, but it will stall higher and hit harder at higher throttle inputs.
A higher stall also slips more, making it somewhat easer to keep the car stationary when you have lower idle vacuum in the case of a bigger cam.
If you're not worried about getting into the fat of the torque curve right away, then I wouldn't worry about a stall converter right away.
I would think you'd be ok with a stock converter with either an LT4 Hotcam or the XE 224/230... There are hundreds of people here that would tell you different.
It can't hurt to try it anyway...
Old Jan 6, 2004 | 02:17 PM
smokerZ28's Avatar
Nothing really wrong with a higher stall until you start getting in the high stalls, like over 4k. After that I think it makes it difficult for city driving, espically in rain or snow. I could be wrong though, converters aern't my strong area.
Old Jan 6, 2004 | 02:23 PM
FacelessZ's Avatar
That's why they make lock-up stalls, for highway driving...
Old Jan 6, 2004 | 02:25 PM
thanks alot guys im thinking about doing a stall im not totally against it...im just weighing out my options . . .i really want the xe230/236 ive heard good gains from it. . . .so for that cam id need a 3000 tc??
alex5366
Feb 17, 2015 08:12 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
cmdeshon
Dec 12, 2014 10:51 PM
Snoman73
Nov 17, 2014 07:22 PM
