what cam?
Old Feb 21, 2004 | 11:11 AM
kyzar24's Avatar
what cam?
im have a 94 z28 with stock heads with every bolt on you can do what cam will be the most helpful? dont wanna port my heads i just sold a set of ported heads just want a little more pep
Old Feb 21, 2004 | 11:30 AM
Fastbird93's Avatar
CC XE 502 (XE 218/224), it's proven to throw about 340ish HP/TQ at the ground on a bolt on stock headed 1.6 rocker car.
Old Feb 21, 2004 | 11:35 AM
LimitedEd1LE's Avatar
If you want a little bigger, go with the XE 224/230 with 1.6 RR. Works great with stock heads. Go to www.cmotorsports.com for info on cams.
Old Feb 21, 2004 | 11:39 AM
Fastbird93's Avatar
Have you seen the 224/230 put 343/343 corrected to the ground though?? Plus it's powerband is going to necessitate a higher rev to hit the peak than the 218/224.
Old Feb 21, 2004 | 11:42 AM
I have not had mine on the dyno, but I can guarante that mine will. I have raced mu buddies '95 vette that was dynoed at 356 rwhp and beat him pretty bad. My car feels great and pulls hard.
All I was saying, is that the 224/230 is going to give you more hp.
Old Feb 21, 2004 | 11:57 AM
Fastbird93's Avatar
Not necessarily on a stock headed car.
I did a search and found the following:
jkipp84's sig: XE 224/230, 2400, 3.73's, Bolt-on's, lots of BMR. Dyno: 326/318 SAE
There's this thread.
Then there's 94formulabz, read his post on the second page of this thread. He made 343/343 SAE, 351/351 STD at the wheels.
I know that's only two examples, but I didn't feel like searching everywhere for more.
Either cam is going to be fine, but bigger isn't always necessarily better.
Old Feb 21, 2004 | 12:49 PM
jkipp84's Avatar
Keep in mind I have an A4. If it was an M6, that number would've been in the 340's.
Either one of these works great with stock heads.
Old Feb 21, 2004 | 02:40 PM
Fastbird93's Avatar
Didn't take that into account. Thanks for the heads up.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
