What brand and where do I get from?
Old Dec 1, 2006 | 02:11 AM
SmokinZ28lt1's Avatar
ok I need some forged pistons,a 3.75 or 3.875 crank,connecting rods, a good cam, hydrolic roller lifters, and forged rods. I need to know what brands are good so I don't buy junk,and possibly their website so I can check them out. thx
Old Dec 1, 2006 | 05:38 AM
Guest47904's Avatar
Guest
It would appear that you have not given enough thought to the build process. Before you can pick out which pistons you need, you need to decide on the CR and rod length. And before you can do that, you need to know the volume of the cylinder head chamber. It would also be nice to have a power goal in mind before you do anything. There's nothing worse than buying a hole bunch of stuff that either doesn't work well together or doesn't work at all.
Your best bet is to purchase a pre-balanced rotating assembly. Complete with everything you're looking for with the exception of the cam. The folks you purchase the assembly from can tell you more about the cam specs you can use.
The folks at TPIS, or Doug Herbert can help with parts. I also believe either Scat or Eagle offers kits as well. there are litterally hundreds of folks you can talk to about your goal.
I would suggest if you haven't already set a goal for your budget, that you do so. I did the same thing you intend to do and now I have a 1/2 finished engine that I can't afford to finish.
Old Dec 12, 2006 | 06:10 AM
waylow's Avatar
This sounds about like what I am about to get myself into haha
Old Dec 12, 2006 | 07:16 AM
SS RRR's Avatar
I don't think either of those kits are sold pre-balanced. Out of curiosity why would it be better to get a pre-balanced kit?
Old Dec 12, 2006 | 08:42 AM
Eric@Victory Racing's Avatar
Eagle and Compstar offer pre-balanced kits.
SmokinZ28lt1,
We carry a variety of rotating assemblies by Eagle, Scat, Lunati and Compstar. Please feel free to browse our website, and don't hesitate to contact us with any questions.
Old Dec 14, 2006 | 05:38 AM
Guest47904's Avatar
Guest
Depending on which way you want to balance it, components bought seperately may not be able to be balanced. The worst nightmare is trying to balance them internally. Some cranks can't be done internally. Others require so much Mallory it isn't worth the machinist's time. If you get the right crank, it could only require removing metal to balance it.
The point being, if you get the right kit, it's already done for you. And yes Eagle (one of many Mfrs) makes pre balanced kits.
Old Dec 14, 2006 | 07:45 PM
SS RRR's Avatar
That's why it's always a good idea to go with a proven name. I haven't heard of many companies where a lot of metal is required to be added... I heard Eagle cranks were that way, but the people I know with them including myself had them balanced by their own machine shops and they turned out fine. I'd much rather prefer my machinist do the balancing. Even if it came pre-balanced I'd still want my builder to check it to make sure which is added cost to the project...
lt1xondeck
Jul 13, 2015 09:03 AM
chevy95z28
Jun 22, 2015 09:28 PM
DETROIT_AREA_00_SS
Aug 14, 2002 08:00 PM
