what is the black plastic box with hoses running to it..?
its on the front of the engine on the drivers side and most cars i see have removed them ...what does it do and ho do i remove it .....thanks
ps i have a 95 trans am
Re: what is the black plastic box with hoses running to it..?
I'm guessing you're talking about the AIR pump? Do a search and you will find plenty of information on it. Check Shoebox's site for diagrams (and everything else under the sun
The AIR pump runs for a couple minutes at startup to help the cats heat up faster. It has no affect on performance. Removing it saves 7# off the front end. You will need to plug the holes in the exhaust manifolds, and cap the 5/8" connection on the inlet air duct between the filter and the MAF.
thanks for responses i didnt know what it was to do a search but i am installing long tube headers so that will fix the exhaust part and the rest i guess just plug off ....thanks
Jan 13, 2015 09:52 PM
Jul 4, 2005 05:00 PM
