What is the best Catalytic Converters?
Old May 25, 2003 | 11:42 AM
Onetuffride's Avatar
I have been searching for a new Catalytic Converter, and I'm not shore which one to go with. I have done a search and still a little confused, but then that is my normal state! I have just installed my borla cat-back system and I'm installing AS&M Headers here next week (Waiting for them to arrive).
So I'm looking for some advice on what others are using, for those that are still using Catalytic Converters. Any help would be greatly apprecitated. Thanks in advance.
Tuff.
Old May 25, 2003 | 12:31 PM
TA Dreaming's Avatar
random tech makes good stuff. not sure if they are the best but ill be going with them. most likely the full system save headers. Trey
Old May 25, 2003 | 02:31 PM
Thanks for the reply, I was looking at Car Sound Cats? Are they any good? I read a post here about the Car Sound Cats and they look like they flow really well. But, I don't see one for the Camaro's? Does anyone have a Car Sound Cat? If so which one works for our cars? Thanks again for everyone's help.
Tuff.
Old May 25, 2003 | 02:52 PM
EviLBoX's Avatar
Carsound are one of the highest flowing cats available. I'd go with Carsound over Random Technology since they flow pretty much the same, but cost a lot less.
Old May 26, 2003 | 12:52 AM
Fatdog's Avatar
Cool
Hot rod mag did a test on about ten of them,catco was the highest flower,Random was about 5th,but they last longer I have heard.My02
Old May 26, 2003 | 01:09 AM
ATMINF's Avatar
I have a CATCO on mine and it passes SMOG with no problems. But I usually run my off-road pipe instaed. The CATCO was also only about $50 bucks if I remember right, I got it from JEGS or Summit.
Old May 26, 2003 | 01:15 AM
mastrdrver's Avatar
Doesnt the Random Cats move the position of the driver side cat and therefor make it illegal?
Old May 26, 2003 | 01:19 AM
ATMINF's Avatar
As long as its close to the factory location it should be okay. I have never seen a smog tech get a ruler out to check a 1/4 inch here or there. But you never know.
Old May 26, 2003 | 03:11 AM
chesee48's Avatar
The best cat conv is none at all
But yea, reandon tech are good but pricey.
Old May 26, 2003 | 04:24 AM
HungryT/A's Avatar
I hear good things about Catco. Does anybody know what's the part number for our cars? There are so many different catco cats at Summit...
thx
Old May 26, 2003 | 05:18 AM
rskrause's Avatar
Moderator
I am using the Random Tech dual cat Y-pipe and making pretty big hp. So I wouldn't hesitate to recommend them, but cost isn't usually how I decide on parts.
Rich Krause
Old May 26, 2003 | 09:52 AM
Hyperspeed97z28's Avatar
The best are NONE or HOLLOW
Old May 26, 2003 | 09:54 AM
rskrause's Avatar
Moderator
As an air breather, I have a different opinion
Rich Krause
Old May 26, 2003 | 10:07 AM
Fastbird93's Avatar
If you're going with the AZ headers, the Random Tech Cat will bolt right up.
NewsBot
Sep 14, 2015 02:02 AM
95craz28
11
Sep 12, 2015 07:47 AM
USN06
Sep 7, 2015 03:30 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Slayer
Aug 17, 2015 03:55 PM
