What Are Best Camaro LT1 Plugs Wires?
Old Dec 21, 2008 | 09:43 AM
  #16
JP95ZM6's Avatar
If you do use bigger wires, you will likely need to develop a new routing. Those metal channels are snug even with factory wires. Considering the factory routing is a real pain to start with, don't make it worse. With headers, routing over the valve covers is nice, but with factory manifolds I don't think that is even an option.
Old Dec 21, 2008 | 10:22 AM
  #17
Originally Posted by shoebox
I've never used anything but the factory wires on my car. People obsess too much about plug wires. There is a point where "bigger" does nothing more for you.
Originally Posted by YoungCompton
I dont know much about the wires bt ima buy this set and hope for the best its reasonably priced
http://motors.shop.ebay.com/_Car-Tru...dZm270Q2el1313
Didn't take long to prove your point, did it Rob?
But since YoungCompton doesn't have a "signature" we have no idea what he's going to put them on. Maybe its a 1,500HP turbo setup with an extreme high voltage ignition system. That's about the only place those wires would make any sense.
PS - do a google search on Vision Motorsports, the supposed manufacturer of that 10.2mm wire. Only thing that seems to turn up is a source that sells lighting.
Old Dec 21, 2008 | 11:56 AM
  #18
YoungCompton's Avatar
Welcome to the YoungCompton Roast lol! as it says in the post "((((I don't know much about the wires)))) but ima buy this set and hope for the best its reasonably priced" i seen what looked like a pretty good deal and i shared the idea. Yes i figured bigger is better on the wires so thanks everyone i learned something new
Old Dec 21, 2008 | 10:19 PM
  #19
IPrice's Avatar
With the extreme list of mods he has I would LOATH to hear how much fun he has trying to run routing on anything larger than OEM.
Hey brother, get some AC Delcos or, hell, Retail Auto Parts brand. (AZ/Shucks/PB's...etc..) They are all 7mms and will be just fine.
Good luck,
Ivan
BTW-Run some over the counter NGK TR5s..can't go wrong there.
Old Dec 21, 2008 | 10:38 PM
  #20
Maverick_997's Avatar
just replaced mine after header install with some 8.5 msd wires and it wasnt to bad to route those. a few cut up knuckles, a zip tie, and a couple hours later it was done
btw they only have 30-50 ohms of resistance i think compared to the few thousand ohm stockers
Jeremy
Old Dec 21, 2008 | 10:58 PM
  #21
lt1bowtiefreak's Avatar
i know msd has there street fire 8mm (500ohms) wires not sure how good they are, then jegs has there brand of 8.5mm and both are around 40-50, has any body else used these? im curious cuz ive been looking at those since i dont have the money to buy the 8.5mm superconductor wires
Old Dec 22, 2008 | 11:07 PM
  #22
texas94z's Avatar
not taylors IMO.
Old Dec 22, 2008 | 11:42 PM
  #23
ACE1252's Avatar
Originally Posted by Injuneer
I had major problems with the stock AC/Delco platinum plugs losing the little platinum pucks off the center electrode and ground strap... but that was many years ago. Maybe they've improved them.
No....they still lose them....all my old plugs were missing them. I guess the get blown out the exhaust.....I hope.
Old Dec 23, 2008 | 12:18 AM
  #24
IPrice's Avatar
I was at AZ last night and asked what kind of wires they sold just to see what other options our friend might have.
You can Special Order MSD 7mm wires for the exact same price as their "oem" Duralast branded ones....$39.99.
They only come in black but I'm sure that the quality isn't bad.
Just thought I'd pass it along,
Ivan
Old Dec 23, 2008 | 08:27 AM
  #25
Jeremy
...though the stockers seem to work just as well...
Old Dec 25, 2008 | 09:50 AM
  #26
fireman's Avatar
Taylor wires--Had 2 sets on my previous Mustangs and they just turn to sh*t in about a year. Tried a set on my Firebird years back with an OTVC setup as well, same thing. Won't EVER buy again.
MSD Superconductors--Bought a set back when car was basic bolt ons. If they are anywhere in the vicinity of the header tubes, they will get hard as a rock and crack open. Not impressed for the $90 paid for them. Won't buy again.
Stock wires-- I don't know if GM uses the same maker for all their wires. My '00 GTP had 26k on it and was exactly one year old when I had a major issue with misfiring over 3500rpm. Tried averything to fix it. In a last ditch effort, I replaced the still new looking stock wires with some Accel Super Stock 7mm wires. Problem solved.
I'e been thorugh 4 sets of wires on my Firebiord in the last 8 years and the best ones have been my current Accel 8.8mm, 300+, cut to fit wires. They have been on the car since '03 and are perfect. They are close as hell to the header tubes as well. They still look and perform like new. I think I paid around $60 for them too.
BTW- [edit] stock Fbody wire routing. I have never even considered trying to route a new set of wires how the factory ones were.
Last edited by Injuneer; Dec 25, 2008 at 12:05 PM. Reason: Do not over ride the language filter.
Old Aug 26, 2019 | 06:41 AM
  #27
Robert Dikes's Avatar
Re: What Are Best Camaro LT1 Plugs Wires?
I just installed ACcel wires 8.0 with ceramic boots and ngk t55 plugs good as any.
95z m6 151×××.
Bbk headers
Flowmaster 80 series exhaust
Off road y pipe
Cat delete
Cai morso
Stage 2 clutch
T-Dubbs
May 22, 2007 10:05 PM
TJ Chapman
Oct 26, 2005 11:45 AM
pHEnomIC
Aug 28, 2004 04:50 PM
notstln18
Jun 24, 2003 04:44 AM
