What am I doing wrong?????
quote:
"Don't lose hope. At least you're not driving a Civic and under the illusion your car is fast. Either way, 14.0 is quick"
When you look at it that way
In response to your post:
I ran the car at the same track Atco raceway, NJ
The stock runs were on a warm day (70 degrees) in November.
The mod runs were on a cool night (52 degrees) in September.
There was only about a 1k mile difference on the car, I only put 5k miles from August 02 to August 03.
The fuel level was the same, no wheel size change, every thing was as close to or better then the stock run.
Stock 14.050 @ 98 mph
Mod 14.065 @ 98 mph
I going to try to get back to the track and try to run w/ the stock MAF and remove the SLP air temp sensor and see if any difference is made.
If that doesn't work headers and 1.6 roller
I wanted to thank you for your insight
Mod 14.065 @ 98 mph
Aaront810
Aug 29, 2020 09:34 PM
