What all controls timing....
Old Dec 25, 2003 | 12:13 AM
  #16
CamZ2811's Avatar
oops guess not
Old Dec 25, 2003 | 12:16 AM
  #17
97Camaro007's Avatar
Even on a Vented opti....? I didn't think that you could put them on wrong because the pin wouldn't fit in the other holes.....i might be wrong....
Old Dec 25, 2003 | 12:17 AM
  #18
Thanks for the help shoebox.....wish i could figure this thing out....but fiirst things first...i will take out the opti again and try from the start....maybe i did put it in wrong and didn't realize it.....
Old Dec 25, 2003 | 12:28 AM
  #19
HesterZ28's Avatar
97 camaro, I just put in my new cc306 yesterday and I had backfire from the intake and your same issues. My timing was off 1 tooth and thats all it took to F*** everything up.
Good luck I hope you get her runnin soon
Old Dec 25, 2003 | 02:21 AM
  #20
atljar's Avatar
For the final time, the CPS sensor is NOT USED FOR TIMING. Thats not the problem.
Cause 1 = You have your rocker arms too tight. Get them to the point where the pushrod doesnt move up/down, then 1/2 turn past and lock. There is a specific sequence to this, and must turn engine over.
Cause 2 = your opti isnt on correctly. Make sure its in the hole, and not in the clover shape. It should almost snap into place. and be flush with timing cover. DONT use the bolts to pull it on.
Cause 3 = You installed your cam wrong. I dont care if 40x people checked it, its easy to mess up. I did mine wrong and SWORE it was right, as did my buddy who helped me. When i went to the track and ran 14s at 97 mph, i knew something was up. Sure enough, it was a single tooth off. You better hope its retarded and not advanced if this is the case.
Old Dec 25, 2003 | 12:34 PM
  #21
Vented or non-vented, people have put them on wrong. Based on your info, that's what I would check next.
Old Dec 25, 2003 | 02:32 PM
  #22
96 WS6's Avatar
I told you... I know how probably don't want to hear it but I think this is the problem like I said before. The vented opti only goes on one way. The hole is every distinctly marked and is a unique shape than the other openings on the back of the opti. It's seems that the problem is not electrical, so I'm thinking it has to be something mechanical.
Old Dec 25, 2003 | 02:38 PM
  #23
Thanks for the help guys.....I will check everything over again and let you guys know what happened.....Thanks again!
Old Dec 25, 2003 | 05:53 PM
  #24
They can only go on correctly one way. They can go on incorrectly several ways.
Old Dec 25, 2003 | 06:16 PM
  #25
97 RedSS's Avatar
You can put a Vented Opti on Incorrectly....I tried to see if I could install it wrong and sure enough, I could.
Cody
Old Dec 25, 2003 | 10:19 PM
  #26
Thanks Cody....I will try the opti when i get back to lufkin!
Old Dec 25, 2003 | 10:43 PM
  #27
97 RedSS's Avatar
Just make sure it pushes all the way flush with the timing cover..When mine went on wrong it wasnt exactly flush with the cover so I would check that before you pull it off..Im sure you can get under the car and maybe check that.
G'Luck!
Cody
Old Apr 6, 2005 | 04:16 PM
  #28
unTAmedLS1's Avatar
Re: What all controls timing....
did you ever get it running I am having the same exact problem and I have been looking trough old threads for the last hour and to my luck not one person has come back and said that they fixed it or found the problem... PLease help there are many of us with this problem and after all this work while it was cold out and doing it in my driveway I would like to see what the solution was for everyone instead of pulling everything apart to see that the opti is on right or the timing chain dots are lined up perfect
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
drt
Sep 27, 2015 04:39 PM
