What all can cause a high rpm miss??
Old Aug 12, 2003 | 01:41 PM
speed76demon's Avatar
Runs good now in lower rpms but when i get on it it misses. It starts around 4500 rpms and stops till a little over 5k then starts to miss again i dont understand it. I have replaced 02's,wire,coil,opti, and plugs. The only thing i can think of is my mechanic said maybe one of my plugs is cracked or split or something. He said he put the scope on them and didnt seem any though. So any ideas man i'm sick of putting money in this car just to get it to run right
Old Aug 12, 2003 | 04:32 PM
nobody knows?? could it do something with my fuel pressure?? maybe running to lean or something just wondering if this is a possiblity if so how do i fix it my neighbor has some gm programs and said that maybe their might be a fuel upgrade for it but i have no clue in programming my car any ideas?
Old Aug 12, 2003 | 06:14 PM
firepheasent's Avatar
I had the same problem but is was my Opti after a process of elimation. You check out you ground strap for your coil and change all the plugs to be on the safe side of things.
Good luck to you.
lt1matt
Mar 21, 2015 07:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
DetroitZ28
Feb 13, 2015 07:33 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
