what aftermarket ignition boxes??
Old Sep 15, 2003 | 10:48 PM
lt1camaroman93's Avatar
What aftermarket ignition boxes can we run? I am looking for something that is good for a nitrous car, meaning good primary voltage increase and good secondary voltage increase, plus the abbility to pull timming.
Old Sep 15, 2003 | 11:01 PM
Hotwire's Avatar
i'm running a crane cams lx91 coil and hi-6 ignition. works great so far, burned completely through a set of cheap autolite plug wires. upgrading to taylor spiro core wires and routing them over the valve covers to keep from burning them again.
w/ the hi-6, you have all kinds of options, a two step rev limiter, self diagnostics, valet mode, etc etc. it's a neat little system.
Old Sep 15, 2003 | 11:24 PM
Was it a plug and play set up on the lt1? does it have adjustible
timming controls?
Old Sep 15, 2003 | 11:30 PM
Hotwire's Avatar
i just got the hi-6s, sounds like you want the trc http://www.cranecams.com/ignition/hi6trc.htm
you can check out the other ignition options they have there while you're at it.
you can get plug and play harnesses for it, i didn't get the harness, just spliced the wires in, wasn't hard at all.
Old Sep 15, 2003 | 11:59 PM
ninetythreez's Avatar
MSD
I used a MSD 6A and LT1 harness from Summit (all $165) for a long time on my old 93 Z28 and it was really great. Easy to install and made an instant difference.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
