What is the advantage of a 6" rod in a 383?
Old Sep 23, 2003 | 12:44 AM
neat's Avatar
Why would you use a 6 inch connecting rod v.s. a 5.7" rod? What are the advantages/disadvantages?
Old Sep 23, 2003 | 03:44 AM
sssalah's Avatar
Rod/strock ratio, its better for high rpm to have a larger number than a lower one. Take for example the SBC 302 which had a 5.7 rod and 3.00" strock, with a ratio of 1.9 and they were known for the high rpm potential. The SBC 400 had a 5.64 rod and a 3.75 strock so the ratio is 1.5. In the same way the SBC 350 is 1.64.
With high ratio the angle of the connecting rod will be lower in relation to the piston at both TDC and BDC and hence less force on the engine block side walls.
At least thats the way I understand it
Old Sep 23, 2003 | 06:19 AM
StudyTime's Avatar
I'm just parroting something I've heard before, but the longer rods give you
"more dwell time at top dead center".
As far as more leverage, I'll be posting at the end of the week if that really is true. So, check back on that one.
As far as the ratio with stroke and rod, don't professional engine builders shoot for a ratio WAY better than the marginal gain of going from a stock rod to a 6" rod?
Ben T.
Old Sep 23, 2003 | 01:39 PM
SStrokerAce's Avatar
Really all of that other stuff doesn't mean much, It's the lighter weight pistons. That's the biggest advantage of the longer connecting rod.
Bret
Devinfoote87
Feb 12, 2016 03:21 PM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
Boss002
Jul 24, 2015 10:47 AM
mrwz28
Jul 8, 2015 09:11 PM
