went to drag strip
Old May 4, 2008 | 04:37 PM
cory123456's Avatar
went to drag strip
so i went to the drag strip for the first time ever and ran a 14.1@100 but in third gear around 4800 to 5000rpms it feels like the power surges a little what could that be from? thanks.
Old May 4, 2008 | 04:39 PM
Knock retard, misfires, low fuel pressure. Tell us more about the car... year, model engine, tranny and any mods. A "signature" is generally a good idea.
Old May 4, 2008 | 05:32 PM
cory123456's Avatar
its a 1996 z28, manual, cai, headers, computer tune, 160* thermo., intake elbow, sub frame conn., and lower control arms and 140000 miles.
Old May 4, 2008 | 08:18 PM
Zeueses 97 RamAir's Avatar
Opti
Opti Spark :d
Old May 4, 2008 | 08:28 PM
cory123456's Avatar
is it bad should i get a new better one or what?
Old May 5, 2008 | 06:55 AM
chris96ta's Avatar
I had the same issue years ago at the same rpm at wot. It was the opti on its way out. The first time i sprayed nitrous the opti blew up right when it hit that hesitation.
Old May 5, 2008 | 07:05 AM
94zgreenmachine's Avatar
Don't go replacing parts without doing a scan of the computer, at least. A data log would be even better. There are several loggers you can use.
Old May 5, 2008 | 08:33 AM
slomarao's Avatar
scan the computer. if you can get to a dyno you may find out whats going on. Typically 2-3 pulls are between $75 and 125. So that would be much cheaper than just starting to replace parts. I would at least change the plugs, fuel filter, clean you air filter.
Do it break up at that rpm in every gear or just third?
Give more info
Old May 5, 2008 | 01:22 PM
93transam1234's Avatar
At 130k doing an opti, coil, plugs, wires, air filter, fuel filter,02 sensors.. is not throwing parts at it...it maintaining the car. Even if the above things are not "problems" they are way past their NORMAL life span.
Go ahead and give the car a full tune up and see how she feels after.
If you still have problems then you can start lookink at other stuff.
Old May 5, 2008 | 01:52 PM
pcgamer4life's Avatar
I can see replacing plugs, wires, filters, etc. But dropping $500 on a new opti and new o2 sensors when you don't know if that's the problem or not seems a little over the top. Some people don't exactly have that kind of money to throw around. "Routine maintenance" or not, I don't think high end components are included in a run-of-the-mill tune up.
Your best option, in my opinion, would be to get new plugs and wires and go from there. Get someone with a fuel pressure tester and see if you're putting out adequate pressure. If problems persist, move up the electrical component line and replace the opti if need be.
Another suggestion is to get a $100 ALDL cable and some free software and data log your car to see exactly what's going on.
Old May 5, 2008 | 02:54 PM
cory123456's Avatar
i have new spark plugs and wires, just cleaned my filter and i do need to chang my fuel filter and i think my neibor has a fuel pressure tester
Old May 5, 2008 | 02:55 PM
cory123456's Avatar
o i forgot it does only happen in third
HAWG
Sep 25, 2015 11:41 AM
pepon214tx
Sep 20, 2015 04:48 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
