well, my waterpump just died....
Old Jul 13, 2006 | 09:44 AM
  #16
user 647483's Avatar
Re: well, my waterpump just died....
Originally Posted by fastchevy
I have a CSR EWP. I removed the A.I.R. pump and used that wiring for the EWP....it was fairly straightforward. If my EWP pops the fuse I'll get an SES light. The PCM will think the AIR pump blew it's fuse. Buttercup and someone else (sorry can't remember) came up with the idea and did a write up.
Has anyone pulled the fuse and confirmed that the SES light does in fact
come on? It would have to be triggered by a sensor or a relay somewhere.
Old Jul 13, 2006 | 10:12 AM
  #17
GreenZLT1's Avatar
stay away from autozone parts! its seems like every part I buy is defective.
Old Jul 13, 2006 | 10:15 AM
  #18
FeelTheSpeed's Avatar
Originally Posted by transamdude95
...but there's no need to remove the water pump drive shaft from the motor...
But you see this is just the thing, I heard otherwise...and now I am leaning towards believing you have to take it out. Because the person that installed my EWP left it in like you just said, and it ended up making a whole heap of problems for me. I'll put it this way, the water pump drive shaft is missing quite a few teeth now lol.
Old Jul 13, 2006 | 10:22 AM
  #19
87lt1rx7's Avatar
Generally anything SMOG related will instantly throw a code. I know my car had a misfire and it let me know about five seconds after it became consistant.
Old Jul 13, 2006 | 10:53 AM
  #20
fastchevy's Avatar
Yes it will throw a code and set off the SES.
Old Jul 13, 2006 | 01:12 PM
  #21
transamdude95's Avatar
It sounds to me like the bushing might still be in your water pump, and the drive shaft is rubbing against it. I've been running my T/A for over a year now with the electric water pump and the drive shaft still on it and there have been zero problems. Although... I have been looking for a diagram of the Water Pump Watchdog system since I cannot find mine anywhere.
Originally Posted by multicar
Anyone tried the Summit $135 electric w/p yet? I wondering if its a clone of the CSI/CSR or Meizere.
Doug
Just got a CSI.
reww86
Aug 29, 2015 06:04 PM
MikeWhitener
Aug 2, 2015 06:17 PM
jwade88
Jun 14, 2015 09:38 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
