well, my waterpump just died....
Old Jul 9, 2006 | 06:14 AM
grandnational007's Avatar
so yeah, my waterpump started pissing out of the weep-hole today...
i gotta replace it so, what do you all recommend?
i was thinking going w/ an electric pump, but what about the reliability of these? anybody running one?
what brand would you recommend, and what p[roblems have you had w/ yours?
any help greatly appreciated, thanks
Old Jul 9, 2006 | 06:44 AM
njenson's Avatar
Re: well, my waterpump just died....
personally when mine goes ill go e-wp with a monitoring system, just in case.
Old Jul 9, 2006 | 07:43 AM
Rising Phoenix's Avatar
Originally Posted by Z28Roxy
My waterpump died about three months ago and I replaced it with a crank driven one.
If it goes again I'll probably try an electric pump - I'm just a little nervous about actually taking the drive gear out of there. Something about working inside the engine and taking the timing chain off worries me =P
So I don't know, this isn't too helpful for you other than stating that an e-waterpump would obviously require more work to install.
BTW, we just used whatever brand the new waterpumps are from Checker/Kragen (not a reman one). I don't trust Autozone crap - I've had so many faulty parts from there it's downright scary. So we just went to Checker and had them pricematch the waterpump. Not only was it about $100 cheaper, it actually saved us 5%
No problems so far, in fact the car is running cooler than ever. Although that could be partially due to having a working thermostat now, and a MadZ28 tune.
edit: The waterpump has a lifetime warranty, too.
Old Jul 10, 2006 | 08:28 PM
Hawk's Avatar
I don't know what your taaking about dude!! You don't need to take off the timing chain or anything, you just leave the drive gear in there and let it free wheel!
I recommend the electric. And, if it does need to be replaced, you can change the electric in under an hour!! It's really easy.......
Old Jul 12, 2006 | 03:47 PM
"White Knight"'s Avatar
you leave that gear in, in case you ever want to go back to stock. There was a post just the other day he wanted to go back for some reason....and he removed it.
I run a Mezire <sp?? electric water pump. Install was simple, I have not had any issues or problems at all. I love it. Mine is not a daily driver, but is extremely reliable--depending on how well your wiring skills are.
Old Jul 12, 2006 | 04:39 PM
user 647483's Avatar
I love my EWP. easy install.
I've considered building a simple warning system (2 LEDs).
I monitor it the same way I monitored my stock one; if the engine
starts getting real hot or you have coolant leaks, troubleshoot it
Old Jul 12, 2006 | 05:05 PM
ulakovic22's Avatar
Ditto with everyone else. Just installed and elec. w/p last month and it has been working great. I admit I'm watching the gauge like a hawk though. I'm pretty impressed how well it has been working out so far.
Old Jul 12, 2006 | 05:53 PM
GMRULZ's Avatar
Miezere EWP 4 years of trouble free service!
Old Jul 12, 2006 | 07:08 PM
FeelTheSpeed's Avatar
I really hope your kidding about this part LOL...
Old Jul 12, 2006 | 07:16 PM
mobleman's Avatar
He's right. All you need to do is remove the coupling between the waterpump and the drive shaft.
Old Jul 12, 2006 | 11:20 PM
StephenDeli22's Avatar
That was nearly impossible to get off in mine. I used a BFH and sat the coupler on a pipe and banged it with a hammer so it would separate from the driveshaft.
Old Jul 12, 2006 | 11:50 PM
ohhh ok, so ur saying remove coupling so whats left is just the flat gear?
Old Jul 13, 2006 | 02:48 AM
transamdude95's Avatar
You will need to remove the shaft and bushing from the water pump when you remove it from the motor, but there's no need to remove the water pump drive shaft from the motor.
And, actually, you can switch out an electric water pump in less than 30 minutes
PS: I got a CSI.
Old Jul 13, 2006 | 08:17 AM
multicar's Avatar
Anyone tried the Summit $135 electric w/p yet? I wondering if its a clone of the CSI/CSR or Meizere.
Doug
Old Jul 13, 2006 | 09:27 AM
fastchevy's Avatar
I have a CSR EWP. I removed the A.I.R. pump and used that wiring for the EWP....it was fairly straightforward. If my EWP pops the fuse I'll get an SES light. The PCM will think the AIR pump blew it's fuse. Buttercup and someone else (sorry can't remember) came up with the idea and did a write up.
