Well... blew the head gaskets...
Old Oct 7, 2003 | 08:45 PM
Larnach's Avatar
And so now I have another project sitting in my garage, need to still take off the heads, hopefully everything is fine.
Anyway. I wanted to know what you guys think I should expect after I finish up.
So far I have a Hooker Catback 160º stat and not much else, car has 125k on the clock, but runs strong. The only time I ran the car, it ran like a 14.6 @ 99.6mph, good mph, weak ET. Anyway, I've got the following being shipped to me and some machine work being done on the heads.
EX Components/Combination Motorsports top end kit (springs, retainers, locks, seals)
Comp Cams Pro Magnum Roller Rockers 1.6/Self Aligning
CSI Electric Water Pump
K&N FIPK
GM Timing Chain
Comp Cams Pushrods
Shorty Headers and Y Pipe (undecided yet)
Cleanup heads and intake, port match intake/heads and valve job on heads. Also maybe bump the compression ratio up a tad when they are milled to for warpage.
Moving battery to the rear of car, 50lbs less on the front end. +10lbs of cableing and misc. -15lbs of other stuff on the car
So anyway, it's not much, but I have a small budget so I figure I got a lot for the money, getting new optispark, plugs, wires, etc. etc.
Any input would be nice, I'm driving the 85hp beater car right now and by the time I get used to that thing pulling, the Z28 should be done and I'll be in for an awakening again
Thanks y'all.
Later
Old Oct 7, 2003 | 08:52 PM
Josh-'04 GTO's Avatar
Sounds like a good start. Definately go for a cam while you're at it, you'll see a real good bump in the horsepower count for an extra $250-$300.
Old Oct 7, 2003 | 08:55 PM
Larnach's Avatar
The only problem with the cam is that I don't want to have it programmed, plus the added expense of lifters, a high quality timing chain, etc. etc. otherwise I'd go for a 224/230 cam, maybe I will, I'll see what next Wed. paycheck brings to me.
Old Oct 7, 2003 | 08:58 PM
Ai's Avatar
Ai
If it overheated any, have the deck of the heads checked for hardness between the two center exhaust ports, and then out on the deck. Oftentimes you'll have issues there with overheated stuff .
Old Oct 7, 2003 | 09:02 PM
Larnach's Avatar
Well you know what happened, I went on a lunch break and the pressed in fitting on the water pump came loose and fell out, it dumped the full load of coolant on the freeway, no steam or anything, then I guess 5 minutes went by, I tried to pass a car and noticed some hesitation and my temp gauge was about a quarter turn past the 280 mark or whatever the highest thing is, totally pinned, I pulled over and the thing wouldn't even start after that. I hope I didn't screw up anything internally.
Old Oct 7, 2003 | 09:11 PM
Ai's Avatar
Ai
Yeah.. I'd definitely have those heads checked out before you put $ into them .
Many machineshops can check them fairly easily & oftentimes wont even charge for it. I'd want a Min. hardness of ~45-50 Rb between the exhaust ports for street stuff & preferably at least 45 out on the deck as well.
Old Oct 9, 2003 | 11:55 PM
Larnach's Avatar
Well it looks like I'm waiting till the end of the month to finish this baby. Going with a 224/230 cam kit from CMotorsports, adding the following while I'm at it.
Edelbrock Headers (only decent CARB approved headers)
K&N CAI
Comp Pro Mag's
Comp Pushrods
Port Match on heads, yes I'm checking them too.
New Opti, plugs, MSD wires.
Hopefully I should see a nice gain over my pretty much stock setup... anybody guess some numbers after I get it dyno tuned?
I will be swapping to an M6 soon so I'm not gonna get a stall anytime soon.
Should I see at least 330rwhp?
Old Oct 10, 2003 | 10:33 PM
Larnach's Avatar
Nobody has any opinions.
Maybe I should wait till mid November and do the heads/230/236 cam and SLP shorties?
Old Oct 11, 2003 | 12:24 AM
PoorMan's Avatar
The 224 w/ heads and headers makes anywhere from 350-380rwhp. The +/- 30 hp I guess depends on head work, type of headers and the tune.
Jeff D.
Old Oct 11, 2003 | 12:29 AM
Z95m6's Avatar
make sure you get a good port job on the heads and save up the money for a decent chain at least the EX duty LT4
Old Oct 12, 2003 | 09:01 AM
akafred's Avatar
water pump
was it a new pump, rebuilt, or original?
Old Oct 12, 2003 | 10:52 AM
Larnach's Avatar
It had about 15,000 miles on it, I bought it new when I did my OPTI.
Old Oct 13, 2003 | 09:39 PM
akafred's Avatar
water pump
so it was new not a new rebuilt ?
the reason i ask is because i had 4 go the same way in a week.
Old Oct 13, 2003 | 09:57 PM
Larnach's Avatar
No it was completley new, I ended up pressing in my own fittings. I'm having it tanked and a CSI installed inside of it.
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jazsun
Dec 29, 2014 12:14 PM
Donwest22
Parts Wanted
Dec 18, 2014 11:10 AM
