welding ceramic coated pipe
Old Jul 26, 2003 | 08:57 PM
Azimiut's Avatar
after so many hits on the darn mile high speed bumps at the store, my Y-pipe has come loose at the collector end near the cat and is causeing a horible leak. but I dont think that a ceramic coated pipe can be welded, the coated must be removed? am I better off buying a stainless pipe, or fixing what I got? also, all my exhaust is currently bolted, welding everything should do away with leaks except those that can occure when a header bolt comes loose, like the other day thanks.
Old Jul 26, 2003 | 09:41 PM
Harpoon Flyby's Avatar
I know ceramic coated pipe can be welded without removeing the coating. The only problem is that the weld will rust somewhat. I would say have it welded. It's the cheapest and one of the best ways to fix it.
HF
KamikaZ28
May 28, 2015 12:45 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
kandied91z
Jul 20, 2002 03:56 AM
