Weird Vibration after 12 bolt install.
Old Jul 24, 2003 | 03:43 PM
xxsaint69x's Avatar
I decided to use my stock steel ds with my 12 bolt. When my car was stock i didnt have any wierd vibrations at higher speeds. Well today i took the car up to 90 mph and as soon as i let off the gas, car vibrated pretty bad, the vibration stoped at around 60 mph. Does this sound like the Ds being out of balance? The weird thing is that everyitng is nice and smooth untill u let of the gas
Marcin
Old Jul 24, 2003 | 03:46 PM
96speed's Avatar
Check the pinion tightness, and throw on an aluminum DS. Could also be a shot bearing as well.
Ryan
Old Jul 24, 2003 | 03:54 PM
xxsaint69x's Avatar
how can it be a pinion?
The rear is pretty quiet, only slight noise at 45-50 mph.
Also what bearing are you talking about?
Old Jul 24, 2003 | 04:01 PM
FormulaDave's Avatar
I have this exact same problem with my 12 bolt..and ive got the steel driveshaft too...im pretty convinced its gotta be the DS
Old Jul 24, 2003 | 04:02 PM
Did you check the pinion angle?
Old Jul 24, 2003 | 05:56 PM
xxsaint69x's Avatar
how would i go about doing that?
Old Jul 24, 2003 | 09:18 PM
xxsaint69x's Avatar
put the aluminum DS on and problem solved...is 2 fingers (about 3/4 inch) between the DS and the tranny enough of slack?
Old Jul 24, 2003 | 09:41 PM
94foormula's Avatar
Marcin did you have to shorten your DS? You have a moser right?
Old Jul 24, 2003 | 09:55 PM
Teek's Avatar
94foormula has a good point.
It was my understanding that M6 cars will require a 1/2 inch shorter DS with a moser 12 bolt rear.
Old Jul 24, 2003 | 10:01 PM
96speed's Avatar
Wink
By using a pinion angle checker...duh
Ryan
Old Jul 24, 2003 | 10:10 PM
importeater's Avatar
How are your ujoints? Id check them first.
Old Jul 24, 2003 | 10:36 PM
CamaroBoy96Z28's Avatar
Strange units dont require a shorter driveshaft right? I know the Moser does.
Old Jul 25, 2003 | 12:56 PM
Strange 12-bolt is OK with the stock DS length. The stock length provides about 1/2" of clearance in the tranny (sounds like about 2 fingers), so it sounds like you are OK. On big HP setups, that clearance needs to step up to 1".
Old Jul 25, 2003 | 01:28 PM
93ZM6Tally's Avatar
I have a similiar vibration with my 12 bolt, which has been somewhat reduced after I had my gears set up. My driveshaft is a shortened steel version. I was going to get a custom aluminum driveshaft and see if the problem goes away.
BigWil
Mar 29, 2015 12:24 PM
maybe2fast
Mar 16, 2015 09:45 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
97z28k&N
Jan 9, 2015 04:58 AM
thenewkid
Nov 18, 2014 12:57 PM
