Weird Tranny prob
Old Apr 16, 2003 | 12:32 AM
1994CamaroZ28's Avatar
Weird Tranny prob
Every now and then when i get on my car it'll hit the revlimiter before it shifts what do i need to look at?
Old Apr 16, 2003 | 01:18 AM
SilverStreak's Avatar
What do you mean it will hit the limiter? Will the rpm's just fly and you won't accelorate? Do you mean you won't shift UNTILL it hits it? Throw some more detail in there. good luck... and just try to explin best you can.. i just had to rebuild my trans
Old Apr 16, 2003 | 01:20 AM
No it accelerates to the point right before it shifts it hits the revlimiter the tranny is brand new strait from gm has around 3k miles on it.
Old Apr 16, 2003 | 01:57 AM
Maybe i'm reading wrong.. but i don't see what the problem is then... at normal speeds it is shifting properly, thats good. When you hit it, the car will accelorate untill red line then shift into 2nd correct? If this is so thats a good thing, that what it should be doing.
Old Apr 16, 2003 | 01:59 AM
Sorry for not making myself more clear, normal driving it shifts fine, but if i punch it on occasion it will get up to speed normal but hits the revlimiter before it shifts. like i gun it then right before it shifts it hits the revlimiter then it shifts.
Old Apr 16, 2003 | 04:31 AM
94z28blue's Avatar
Weird Tranny prob
its a full throttle shift? make sure it is in overdrive, does it kind of teeter at 6500 for a sec and shift? Keep checking your fluid, try not to fry it cuz that is a hassle. If you just dont like the way it shifts put a B&M shift kit in it those help a lot
Old Apr 17, 2003 | 08:30 PM
kjlvilla's Avatar
If your engine is hitting the rev. limiter before it shifts then you probably have an engine driveability problem. Most common is a plugged fuel filter. The pcm is looking for a specific output shaft speed with WOT before it will shift, if the engine will not power the car to that speed the engine will hit the limiter before the shift occurs. The most common complaint is: on the 1-2 shift, the trans will not shift WOT until I back off the throttle. If this is your concern, check sensor inputs, especially tps. If it is ok, then try fuel filter. Good luck.
Old Apr 17, 2003 | 09:01 PM
draggerxlt1's Avatar
i have the same problem. when i get on it it gets to around 4500 or a little more then revs and pops, and doesnt shift till i let off and get back on it slower. what should we check and how? someone told me something about a clutch pack that needs to be replaced, ive never heard of a clutch pack for automatics? i hope its just somethin unplugged, so what should we check? thanx
Old Apr 18, 2003 | 01:40 AM
Mellowdork's Avatar
Ive been through 3 trannys. All of them did that. I do hear a shift kit helps but it doesnt cure it. Ive been trying to find a fix for this for a year now and still havnt found one.
freddy
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
