weird ticking?
Old Nov 16, 2008 | 12:33 PM
YoungCompton's Avatar
weird ticking?
when i put my car in drive and reverse it makes a soft but kinda loud ticking noise. but when in park it stops? and didnt notice it while driving only at stops?
Old Nov 16, 2008 | 12:38 PM
LaredoZ28's Avatar
is it a constant tick or just once when you put the car in gear? If it only does it when u put it in gear it sounds like your U-joints.
Old Nov 17, 2008 | 03:17 PM
how much is that to fix?
Old Nov 17, 2008 | 06:10 PM
LaredoZ28's Avatar
it depends if you go with stock ujoints or the stronger ones. for stock like 40 bux plus someone to change them out for you if you cant do it your self.
Old Nov 18, 2008 | 02:49 PM
DelSoto's Avatar
Not to say you don't need U joints but they are not the cause of your tic. Pull the inspection cover off and check that your torque converter bolts are tight.
Old Nov 18, 2008 | 04:28 PM
red 95 z28 lt1's Avatar
i cant see how it would be the u joints if the car is not moving when the ticking happens
Old Nov 18, 2008 | 04:40 PM
thanks everyone it did it once yesterday and i havent heard it since
Nayr
Mar 3, 2023 08:34 PM
1slow93z28
Sep 1, 2015 06:22 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
97z28k&N
Jan 9, 2015 04:58 AM
offlikeaherdofturtles
3rd Gen / L98 Engine Tech
Aug 5, 2002 02:56 AM
