Weird Thing Happen Tonight
Old Nov 1, 2006 | 05:58 PM
playa7970's Avatar
well while i was driving the car tonight and WOT it, all the lights including the interior lights and engine cut in and out i pretty much lost power any ideas what happened?
Old Nov 2, 2006 | 08:32 AM
playa7970's Avatar
ttt
Old Nov 2, 2006 | 08:37 AM
Javier97Z28's Avatar
Moderator
Check grounds.
Old Nov 2, 2006 | 08:41 AM
playa7970's Avatar
thanks for the reply javier any idea or pictures where there all at?
Old Nov 2, 2006 | 08:45 AM
Moderator
Check your engine to frame ground strap (bolts in with the coil).
Check your battery cable ground wire.
Check the misc grounds that are hooked up to the front framerail under the hood.
No pics tho, sorry man.
Old Nov 2, 2006 | 08:47 AM
playa7970's Avatar
its alright thanks alot though
Old Nov 2, 2006 | 09:42 AM
OBE1 95Z28's Avatar
I believe an intermittent ignition switch can cause power outage issues. Here's a write-up from Shoebox's site: http://shbox.com/ignsw/ign_switch_repl.html
Old Nov 2, 2006 | 10:38 AM
playa7970's Avatar
well i checked all the ground and they seem to be ok, ill give the car another test drive if the problem happens again i guess i have no choice but to replace the ignition switch thanks obe1 i never thought of that as a possibility,is there any way to test the switch to determine it is bad?
Magenta_Hearts
Mar 5, 2015 07:01 AM
97z28k&N
Jan 9, 2015 04:58 AM
Hal Fisher
Sep 14, 2002 09:36 PM
BLUESMAN
Aug 26, 2002 06:07 AM
guionM
14
Jun 19, 2002 08:30 AM
