Weird starting problem
Old Jan 27, 2006 | 11:11 PM
3400Camaro's Avatar
On the Z28 I just bought, when i turn the key the engine rolls over, and over and over and over, and most of the time won't fire, until I stop, and try again, and it fires right up. Anyone have any ideas? I thought maybe opti but what I don't understand is why if I try a second time to start it, it fires in a snap, no matter how long I tried it the first time. It runs fine after start up, and doesn't seem to matter if it's hot or cold. ?????
Old Jan 27, 2006 | 11:48 PM
Dave89IROC's Avatar
Re: Weird starting problem
check fuel pressure
Old Jan 28, 2006 | 12:40 AM
red 95 z28 lt1's Avatar
another vote for fuel pressure
Old Jan 28, 2006 | 01:12 AM
MyShibbyZ28's Avatar
Third vote for fuel pressure. I actually made a diagnostics page on my website in my sig. Hardstarting is the first one I just did, maybe it can help you out.
Old Jan 28, 2006 | 05:26 AM
Guest47904's Avatar
Guest
More than likely his pressure, once it comes up, will be fine. He probably has a problem with the check ball in the fuel pump allowing the fuel to drain away from the fuel rails.
Old Jan 28, 2006 | 09:01 AM
3400Camaro's Avatar
Thanks guys. I'll check out your site shippyZ28.
InfernalVortex
Jan 17, 2015 09:35 AM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
jj71787
Dec 30, 2014 02:15 PM
NewsBot
Dec 3, 2014 12:30 PM
