Weird problem with my temp gauge in the morning..
Guest
Posts: n/a
I like to go start my car like 10 mins before I leave for work in the mornings just to warm it up a bit (damn you, winter).
The past three times I did it, after just about 10 mins, I go out, and the temp gauge is way up in the red, check gauges light is on, and the (heat) vents are blowing out cold cold air, like the AC.. If I turn the car off for 5 seconds, then start it again, the gauge drops, and it instantly blows hot air. Weird..
Then this morning, it did it again, but instead of turning it off, I just started driving. Less than a min later, the temp gauge dropped to where it should be, and instantly the air changed from freezing to warm..
Weird.. Any ideas?!
thanks!
ps - the car is a 96 Z28
Weird.. Any ideas?!
thanks!
Re: Weird problem with my temp gauge in the morning..
try bleeding your cooling system you could have a air pocket causing this and when you drive it or shut it off your moving the air pocket into a different past of the cooling system...
Magenta_Hearts
Mar 29, 2017 08:54 PM
ro2207
Dec 4, 2014 06:18 PM
