weird misfire issue
Old Oct 28, 2011 | 08:49 PM
96WS6TRANSAM's Avatar
weird misfire issue
Want to know if anybody has ever ran into this or something like this car is in miami getting tuned the issue is car will misfire and timing goes all over the place when the alternator is hooked up when it is disconnected it runs good have tried 3 alternators swapped in a new dfi computer tried shielding the plug wires and alternator had battery in trunk moved back under the hood and still the same any help would be appreciated
Old Oct 29, 2011 | 05:14 AM
Guest47904's Avatar
Guest
Re: weird misfire issue
I would think there could be a connection to the alternator at the supply voltage to the optical distributor. Look at the 12volt line going to the opti with a scope when the alternator is in place. Once you do that, we'll go from there.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
SigSauer40
Exhaust System
Apr 29, 2015 09:02 AM
Alex Barnes
Jan 24, 2015 10:21 PM
97z28k&N
Jan 9, 2015 04:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
