Weird Left 02 voltages.
Old Aug 4, 2005 | 07:16 PM
Silvershark's Avatar
I replaced both sensors with AC Delco 02's just a few days ago. Both sensors only have about 3 days of driving on them.
My left sensor on startup/open loop is at .058 via freescan, my right 02 is at .448.
These voltages on the left and right stay the same until I go into closed loop.
My voltages on the right 02 go anywhere from .48 to .9 as normal, where as my left 02 sensor stays right around .040-.058 most of the time and will occasianally jump to .100 or .900.
The 02 sensors are new, new spark plugs, new injectors.
Could an exhaust leak cause the weird voltages I am seeing during open loop as well??
I am really lost.
Thanks.
Kendall H.
Old Aug 4, 2005 | 09:26 PM
Josh'95Z28conv's Avatar
Re: Weird Left 02 voltages.
Im no pro on LT1s, but exhaust leaks can cause all kinds of weird problems. If you think you have one, fix it first. If the sensor is seeing more oxygen, you will get those lean readings. Are you getting an ses light?
Old Aug 4, 2005 | 09:30 PM
Nope, thats the weird thing, no SES light. The only exhaust leak I could think of is where my number 1 primary header collects to the rest of the headers on the drivers side. It is like a slip fit connection. I didnt use a exhaust clamp or anything there. They are Hooker headers, so if anyone has these headers please let me know if it is required to put a clamp of some sort there.
It just seems really odd that my voltage readings are really weird on the drivers side but not setting an SES light.
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
fift5
11
Oct 1, 2015 10:31 AM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
Daluchman1974
Sep 11, 2015 06:12 AM
