weird knock shake in motor
Old Apr 9, 2006 | 01:47 PM
Ws6Envy's Avatar
New motor installed last weekend. First startup was good with no major issues.
But after 1st drive 1/4 mile while its idleing the engine makes a hollow deep metal on metal noise and the entire motor twists to the right (drivers side) for half a second and then does it in closer and closer incriments....
any ideas?
backround....that might help....
motor was balanced for a stock flexplate, but i decided to go manual later on with a stock flywheel.
There seems to be a lot of exhause leaks causing random backfires
any info appreciated
Old Apr 10, 2006 | 06:24 AM
Ws6Envy's Avatar
Re: weird knock shake in motor
ttt
Old Apr 10, 2006 | 11:59 AM
Loadre's Avatar
Sounds like rod knock from the brief description.
Old Apr 10, 2006 | 05:49 PM
Ws6Envy's Avatar
update...traced the knock down to cyl. 5, if i pull the injector harness the motor stops clunking...
also the o2's read .300 / .800
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Mar 15, 2015 10:45 PM
97z28k&N
Jan 9, 2015 04:58 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
