Weird Issue Adjusting Valves
Old Jul 9, 2005 | 03:07 PM
ibanez6rg's Avatar
I adjusted the rockers on my Dad's Corvette today and for some reason everytime I went to TDC #6 the #2 exhaust valve came up a little bit (~1/4"). Shouldn't it be at the bottom of the cam lobe TDC #6? All the other one's were fine, but only had this issue with one lifter. Went through a few times and did it everytime.
Old Jul 9, 2005 | 10:31 PM
MachinistOne's Avatar
Re: Weird Issue Adjusting Valves
Are you saying that valve sits higher than all the others?
Old Jul 10, 2005 | 12:17 AM
ibanez6rg's Avatar
The lifter just comes up a little. It's not all the way down like all the others are when adjusting them.
Old Jul 10, 2005 | 12:25 AM
Jameslt1TA's Avatar
The pointer on your balancer could be off. I only use the tdc method to get the valves close. You should adjust them with the engine running, its more acurate IMO.
Old Jul 10, 2005 | 12:34 AM
ibanez6rg's Avatar
Yeah, I thought it was pretty odd that all the other ones were fine though except one.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
97z28k&N
Jan 9, 2015 04:58 AM
