Weird idle and check engine light
Old Jun 6, 2007 | 10:42 AM
pcgamer4life's Avatar
On my 94 z28, my SES light comes on occasionally. My scanner is only for OBDII, and the ones we have at work for OBD I (autozone) got stolen a while back. No other parts store can scan OBDI in my town. Anyways, so I got the 'key' to jump the two pins on the ALDL port and when I do it, the engine light just stays on. It doesn't flash any codes, it's just a solid light. I tried doing it with the engine running, and it's just a steady flash one after the other... what could be wrong? Why can't I pull any codes?
A second question, my idle is really odd sometimes. When I'm sitting at a stoplight, sometimes it will jump up to 1200-1500 RPM, sometimes it drops unusually low almost to the point where it dies... around 400 rpm. I've never had it die on me, but I'm wondering what it is. Could it be my IAC valve or something similar? Or is this a common problem with an easy fix?
Old Jun 6, 2007 | 12:04 PM
2000GTP's Avatar
The jumper method will not work on your car. You could always look into purchasing a cheapo Actron scanner which will read your codes.
Old Jun 6, 2007 | 12:50 PM
JAB's Avatar
JAB
Yeah, the jumper method to get codes only works up '93s.
You could also buy a cable and get Freescan on a laptop to pull codes if you had the intention of ever tuning yourself later on.
Old Jun 6, 2007 | 05:45 PM
The "cheapo" (~$30) Actron scanner does nothing more than short the pins. It won't work any better than a paper clip. He needs free scanning software (FreeScan, DataMaster) or a used "real" scanner like an Auto X-Ray.
Old Jun 7, 2007 | 12:54 AM
Wow, that sucks. I've got ProScan software and cable, but it's for OBD II only. What would be a good, cheap, effective software/hardware package for OBD I (and OBD II) scanning and maybe tuning?
Old Jun 8, 2007 | 11:34 AM
Free software - scanning only:
-Freescan
http://andywhittaker.com/ECU/FreeSca...0/Default.aspx
-TTS Datamaster (20 free runs, then asks you to license)
http://www.ttspowersystems.com/
Cable:
http://www.akmcables.com/
Tuning software - not free:
LT1_Edit
http://www.carputing.com/
TunerCat
http://www.tunercat.com/
Old Jun 8, 2007 | 01:02 PM
JAB's Avatar
JAB
I've got an AKM cable, Tunercat, and Freescan. Works great! About $180 total it took for it all.
Old Oct 11, 2007 | 04:36 PM
Munson's Avatar
yeah, unfortunately tunercat is like 500 dollars now.. which is rediculous.. the one they sold to jet that is.. Are you using the C.A.T.S. program for tuning?
Old Oct 11, 2007 | 04:42 PM
JAB's Avatar
JAB
They only sold their OBDII program to Jet. OBDI Tunercat is only $70 still plus like $20 bucks for each ECM def. file.
Old Oct 11, 2007 | 04:57 PM
Munson's Avatar
<-- obdII
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
