Weird CHECK GAUGES light
Old May 16, 2006 | 06:57 PM
veee8's Avatar
I've noticed this year that when I first start the car with cooler ambient temps (ie. morning or sitting for a while), with rpms 2500 and higher, the "Check Gauges" light will flicker on. It doesn't stay on, just flickers. I never really noticed it before this year, but unsure if it has allways done this. It's been a little cool lately, 40*-60*. Oil pressure seems to be about 75 psi when cold. Any ideas????
Old May 16, 2006 | 09:04 PM
Ace_437's Avatar
Re: Weird CHECK GAUGES light
Dying battery mabey? My guages in my Jeep would do that when my battery was going out. Put a new one in, and haven't seen it since. Just a though I guess.
Old May 16, 2006 | 09:10 PM
veee8's Avatar
I don't think so. All info on the gauges look good when the light flickers. It almost like a warning to keep the revs down on a cold engine Works good for that!!! Still bothering me though.
Old May 17, 2006 | 04:20 PM
veee8's Avatar
Well it may be a voltage issue. I payed a little closer attention to the volt gauge. It does drop down for a second that bounces back. It doesn't do it when its good and hot. The car always starts fine. I have always been chasing what I think to be low voltage output but have been told it was within spec. About 13.5 volts on the gauge and in pcm when cold, 13 or so with stage 1 fan,then 12.5 or so stage 2 fan idling in gear hot. I have covered my bases, and have just lived with it. I've changed the alt. (140 amp) 3 times, 2gauge battery cables,added additional grounds,same results. What are you guys running for voltage at various ranges?
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
