Weighted Balancer Question
Old Jun 2, 2011 | 08:26 AM
hairbear21's Avatar
I am replacing the opti, and I bought a new crank balancer as my old one was rotted. I noticed that the stock balancer has a weight in it. Do I need to put this weight in new balancer as well?
Thanks!
Old Jun 2, 2011 | 09:01 AM
mrmint69's Avatar
Re: Weighted Balancer Question
My supercharger kit came with a new one and they had me thansfer the old weight. What kind are you going to use?
Old Jun 2, 2011 | 09:08 AM
hairbear21's Avatar
I was thinking that it needed transferred. I'm just running a stock replacement. The good stuff goes in when I can convince the wife that her car needs a rebuild
Old Jun 2, 2011 | 05:12 PM
Do you mean the little brass plug in one of the damper holes?
The unit is not a "balancer", it's a damper, and should be neutral balanced. There is mention of the factory fine tuning the dampers with the little weights to make minor tweeks to the engine balance, but I'm not convinced they are there for any purpose other than neutral balancing the damper assembly.
It becomes more logical, when you realize the damper hub is not even keyed to the crank, and can be installed in any position, and can slip.
HectorM52
Jul 30, 2017 11:46 AM
Newgmman
Feb 25, 2015 02:53 PM
1963SS
Feb 6, 2015 10:05 AM
Nostang 96z
Sep 15, 2002 10:15 PM
