correct operating termperature?
Old Jun 2, 2011 | 02:32 PM
kksi's Avatar
I recently had my 94 Z LT1 serviced in which they had to replace a heater core. At the same time they replaced the t stat. I used to run when the engine was fully heated about 180 degrees and now run 200. is this a normal operating temperature? I checked the bleeder and no air was found....thanks
Old Jun 2, 2011 | 03:30 PM
Re: correct operating termperature?
http://shbox.com/1/4th_gen_tech2.html#cooling
Do you know what degree thermostat they put in and if it was the correct long style LT1 thermostat?//
Old Jun 2, 2011 | 05:18 PM
kksi's Avatar
Not sure but done at Pep Boys. They should know their stuff but I'll check.
Old Jun 2, 2011 | 06:26 PM
Yes, you should check.
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
