Weight of "T-tops"
Old Jul 15, 2003 | 04:59 PM
  #16
BUBBA's Avatar
Just curious. How do you gain by removing the T-Tops? Wouldn't you lose by screwing up the airflow?
Old Jul 15, 2003 | 05:02 PM
  #17
snorkelface's Avatar
Here's a link:
http://www.jegs.com/cgi-bin/ncommerc...71&prmenbr=361
I'm talking in terms of AutoX, where you don't get up to a high enough speed for aerodynamics to come into play.
Old Jul 15, 2003 | 05:31 PM
  #18
RKB4C's Avatar
Bubba, I wasn't talking about removing the t-tops, I don't have t-tops and simply wondered what the weight diff is. I assume hardtop (no t-tops) is just as aerodynamic...
Old Jul 15, 2003 | 05:48 PM
  #19
Zerosheaven's Avatar
wait a minute....if you wighed the ttops and they come out to be 12 pounds each, that doesnt necesarly meen it is 25 pounds heavier than the hard tops, because you are weing it against a car that has a hard top , not a car with no top,so i bet the hard top wiehs about 12 pounds thus ttops being 12 pounds heavier....damn it all makes sense in my mind but its hard to explain...you guys follow me??
Old Jul 15, 2003 | 05:55 PM
  #20
JordonMusser's Avatar
West South Central Moderator / Special Guest
Lexan does NOT work well for a street car, as it scratches very easily...
Old Jul 15, 2003 | 06:00 PM
  #21
I'm sorry, I should have clarified my statement. I wasn't concluding that a t-top car would weigh 25lbs more than I hard-top car, just that the total weight of 2 t-tops comes to about 25lbs. We follow.
Old Jul 15, 2003 | 06:06 PM
  #22
What about with the addition of some dsort of coating? I've seen some around for lexan. The units Jegs sells claim to be scratch-resistant.
Old Jul 15, 2003 | 06:13 PM
  #23
ZPaul2Fresh8's Avatar
I'll add a little opinion here
I just did a t-top conversion. The center section of the pillars that is removed when doing a t-top conversion are pretty beefy. They have to weight 10lbs a piece! Believe it or not they are alot heavier than one would think. I'll see if I can find one to weigh...
Ok, just weighed they were about 10lbs total... add all the metal trimming I did and it'll probly total to 2 lbs
Old Jul 16, 2003 | 06:22 PM
  #24
ahhhhh my bad. thanks for clearing it up
brothaslide
Jan 9, 2016 12:11 PM
95chwagon
Oct 16, 2015 12:24 PM
NewsBot
Sep 14, 2015 09:20 AM
karpetcm
Aug 14, 2015 03:02 PM
bunker
Aug 1, 2015 10:10 PM
